Looking for manual for a flair 3055 air exchanger #43300 serial #7c0394003316
I have replaced both hepa filters on Honeywell enviracare 43300 air purifier and it is rattling, why?
something is loose maybe you put one in a little crooked and that is whey it would rattle or the screw that holds them in is loose , good luck
May 19, 2014 | Honeywell Air Purifiers
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
Apr 28, 2012 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
How do we clean the fan on our Flair?
take the grill of and get a soft cloth and lubricate the center of the motor
Mar 17, 2010 | Ecoquest Flair Air Purifier
Flair sparking
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 09, 2009 | Ecoquest Flair Air Purifier
REPAIR ON MY FLAIR
Hi Bonni,
If you bought it new from EcoQuest, the record should be available from EQ Customer Service, or from the Dealer you purchased it from. You should have received (and filed) a warranty card. They should be able to verify who sold it by the serial number, and give you warranty information from that.
Since we techs here at FixYa aren't employed by EcoQuest, we don't have access to the serial number records; you will have to contact the EQ Customer Service there as well.
As for the repair, you would have been given an RMA (Returned Merchandise Authorization) number; without this, you may have difficulties with EQ, since this is how repairs and returns are tracked. Did you deal with this personally or through a Dealer? In any event, they should be able to cross-reference it by serial number and date of service.
EcoQuest Customer Service is at 800-989-2299, or at
customerservice@ecoquestintl.net
if you prefer email.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 05, 2008 | Ecoquest Flair Air Purifier
Flair
You need to order two ceramic plates and a lint filter. The lint filter is the one that goes on the back. The two glass plates are what ionizes the air. They do not make them from glass anymore. You will need to go to the ecoquest website nd order the parts. It will run you right about $75. Ecoquest bought Flair out a few years ago. Hope it helps.
http://www.airpurifierrepair.com/index.aspx?id=38&gclid=CIuXr5H1mJYCFSCcnAod_GOy7A
Jul 24, 2008 | Ecoquest Flair Air Purifier
Flair air purifier
You can download the users manual and troubleshooting guides from the Ecoquest web site.
http://www.ecoquestintl.com/customers/owners_manuals/index_home.asp
Oct 21, 2007 | Ecoquest Flair Air Purifier
Heating & Cooling Logo
601 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
