Question about Philips AZ1040 Cassette/CD Boombox
I have a Philips Model# AZ1040/17 CD Boombox. I was pushing the "Mode" button and display showed the volume level. It went from 9 to 0 and now I can barely hear anything with the volume knob turned all the way up. Can't figure out how to get the volume "level" back up. All it did was go down when pushing the mode button. Tried everything. Any suggestions? Thanks
SOURCE: Philips magnavox won't turn off and stay in demontration mode
Hold both volume buttons at the same time for 6-10 seconds and that will reverse it. This has been proven to work!!!! YEAH
Posted on Jun 22, 2008
  • 3 Answers
SOURCE: sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Posted on Sep 04, 2008
Ajkill
  • 2035 Answers
SOURCE: CD operation problem. Need manual.
Please click on this link and download the operation manual :
http://safemanuals.com/user-guide-instructions-owner-manual/PHILIPS/AZ1010-01-_E
Good luck..........
Posted on Oct 24, 2008
  • 4 Answers
SOURCE: Philips HDRW 720/17 stuck in '':demo'' mode???
Okay. I found that there IS a manual release for the disc tray UNDERNEATH the unit. It is a sort of toggle lever that you have to slide to the other side and that releases the disc. The Manual does not even mention this manual release lever!
Also, it may be hidden or covered by a paper like cover.
GL
Posted on May 14, 2009
TOM2-TOM2
  • 110 Answers
SOURCE: Retail mode
Try pressing "volume up" and "volume down" at the same time on the keyboard.
Posted on May 20, 2009
2014 highlander radio and CD player no sound when turning up volum the audio symbol shows increasing no sound.
Your vehicle has a three year ... 36000 mile warrantee on the sound system... "ENTUNE"
WHICH (OH-BY-THE-WAY)... has a ton of customer complaints against it...
My very best recommendation is to RUSH it back
to the dealer for warrantee work
Ref: BBB Industries TECHNICAL SERVICE BULLETINS
(Log-in required (but certainly worth the effort)).
Entune Audio Head Unit Software Update (Panasonic)
BBB Industries Premium Alternators Starters Power Steering Products
Nov 04, 2016 | 2014 Toyota Highlander
You'll just need to disable the Random Play mode. I'll give you the link to the manual in a minute.
Oct 24, 2008 | Philips AZ1020 Boombox
Why can't i get cup size in capresso impressa?
Hold the button in, until it says "Enough?" then release..
When you have the right amount, push the button again.
Jul 06, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Trying to record but when I push the "record"
Get the manual...
http://tascam.com/product/cd-rw750/downloads/
Record READY switches the unit into a Monitor mode so you can set your levels for when you finally initiate recording.
Jul 28, 2011 | Tascam CD-RW750 CD Recorder
I can't get any volume from the boombox. It's like the volume is muted for all functions. Any suggestions?
Please make sure that you have selected the correct function.Press the Function/Standby button to select Radio,Tape or CD mode in the boombox.Press the volume +/- buttons to increase or decrease the volume on your RCA RCD135 Cassette/CD Boombox. Also check the display and make sure that the volume level is adjusting when pressing the buttons.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jul 03, 2011 | RCA RCD135 Cassette/CD Boombox
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Cheers
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Philips AZ1040 Cassette/CD Boombox Logo
82 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
