Aeg oko lavamat 6100 manual - Washing Machines
EngineerGR
  • 119 Answers
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Posted on Apr 09, 2008
SOURCE: AEG Oko-lavamat 538 manual
www.manualshark.org/manualshark/files/5/pdf_10471.pdf
Posted on Dec 10, 2008
SOURCE: My AEG OKO-Lavamat 72600 shows error code C9 what
My ariston aqualtic has finnish as language how to change to for ex english
Posted on Oct 30, 2009
  • 174 Answers
SOURCE: aeg oko lavamat 72600 update, ce error code
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Posted on Jul 20, 2010
Testimonial: "Cheers thanks very much, washer now working, great help"
kapishtech
  • 2272 Answers
SOURCE: AEG OKO LAVAMAT 72630 is showing E20. what does
Error code E-20 means drain problem. It means that the machine is not draining water correctly. Check the drain hose, to see if it is kinked or folded over. It could also be that the drain pump or drain hose are clogged. Drain the pump (check behind the little panel at the bottom right of the machine), first draining via the small emergency drain hose if you want to avoid a large puddle.
Also get the fluff filter removed and checked.If the filter is clogged then it will not let the water to get drained. The fluff filter is behind the little trapdoor below and to the right of the drum on the front of the machine. Open the door, unscrew the filter, and pull it out. It will be covered in smelly slimy multi-coloured fluff, which you need to remove. When you remove the filter, there is a good chance that a fair bit of water will come out at the same time, so, if you can place a very low bowl or similar below the filter before you unscrew it it will save you from having to mop the floor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 28, 2010
Where is the filter for die AEG lavamat 538 washing machine and how do you clean it?
The only filter/screen I am familiar with is the one in the hoses the supply hot and cold water to your machine. They should be checked once in a while but I have never found much in them.
However, the manual for your machine is located here:
AEG OKO LAVAMAT 538 Operating Instructions Manual
Best wishes,
Joe
Aug 24, 2016 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Hi can anyone help me please im looking for a user manual for an AEG oko lavamat 75620 washing machine
do google search for "user manual AEG oko lavamat 75620" on page 2 about 4th down you will see a pdf manual for your model ( it's the "update" model but they are virtually identical to use ) don't download straight away it's foreign but don't despair click the option Translate this page and you'll then download an english version of the standard commonly experienced when Nigerian or Ugandan ex govt ministers let you know, via email, of an opportunity to help them smuggle millions out of their respective countries. never-the-less you will be able to run your machine from it.
Mar 17, 2013 | AEG Washing Machines
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
Washine machines
Yes. There is a part that allows you to connect the cold water supply to both the hot and cold inlet hoses. It has worked successfully on our 6100 for 8 years or so. I think it was part of the original kit rather than a subsequent purchase - it's a Y-shaped yoke with an inlet connection and two outlets that accept the two hoses feeding the inlets of the machine. From memory i tink the situation is mentioned in the user manual somewhere.
Jun 10, 2008 | AEG Lavamat 72640 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Regards,
EngineerGR
Apr 09, 2008 | Washing Machines
Washing Machines Logo
390 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
