Question about Fisher and Paykel IWL12 Top Load Washer
Lid lock stays on and constant beep on excellence washing machine
When i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps.The machine is only 1 month old
  • Joy B Jun 17, 2008
    My washer is 4 years old and I never had a problem,until this past week-end. I have 2 wash lights and 1 spin light that are lit and the washer keeps beeping. When I hit the "Pause" button the beeping stops and the lights go out, but the washer still does not work. I unplugged the washer overnight and restarted the washer and it ran through one cycle and than the same problem occured. Help! Dirty laundry is piling up.
I have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
Posted on Jan 26, 2012
I am having the same issue and hope someone can post a solution. I have found a work around though. Mine does it when it is on a 'Regular' wash cycle, I found that if I put it on Permanent Press it works fine.
Posted on Aug 29, 2008
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Light stays when door closed
sounds like you are in diagnostics mode.
Press Wash temp down and Power at the same time to get out of it from memory (although this is for the older models).
If this is the wrong button combo, call F&P and they will probably give you the correct combination for your model machine.
May 22, 2014 | Washing Machines
Fisher paykel washer. turn on 3 progress lights up only, cannot switch off power button. When off the lid lock red light is on
this is a fault in the motor controller fault. the fault code number is 140. it may have a problem with the motor windings / RPS also. you will need parts from F+P.
Nov 12, 2013 | Fisher and Paykel IWL12 Top Load Washer
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
Mw512 beeps and wont start
The lid switch sounds logical. That would certainly halt the cycle. I'm not sure what actuates the lid switch on your particular model but check it as well. Good luck.
Jan 13, 2013 | Fisher and Paykel Washing Machines
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
May 30, 2012 | Maytag Washing Machines
Fisher and paykel washing machine stopped mid-cycle and beeps constantly. 2nd button in is solid green.... 5.5kg smart drive model.
If the light that stays on when beeping is 7th from the right then the machine has a pressure transducer which is out of range, the motor controller module (electronic) will need to be replaced.
Apr 22, 2010 | Fisher Washing Machines
Fisher and Paykel IWL12 Top Load Washer Logo
1,164 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
