Question about Bosch 24 in. SHU43 Built-in Dishwasher
Switch Postions SHU43C02
Can anybody give me the positions of the switches when they are operating (ie: Normally open, normally closed, etc.) and off. I am particulary interested in the tow switches in the water level switch and the flood switch.
Thanks.
You need to use a tester and check for yourself for whatever you are looking for.
Posted on Jun 10, 2008
Says hood is open but it’s closed?
The hood-switch is usually a spring-loaded normally-closed type, meaning that it is closed, ie sensor wire grounded to bodywork, when nothing is pressing it.
Closing the hood presses and opens the contacts, isolating the wire from ground.
Open your bonnet - sorry - hood, and firmly press the silver rod which is the switch.
Does the fault still appear?
Then check that wire from this switch is secure, not shorting anywhere.
If it shorts to grounded body work, it will be seen as 'hood switch closed'.
Nov 20, 2017 | Cars & Trucks
How to reset windows on is 350 lexus 2007
(a) Turn the engine switch on (IG).
(b) Halfway open the power window by pressing the power window switch.
(c) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 1 second after the power window is fully closed.
(d) Check that the AUTO UP/DOWN function operates normally.
If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time. If not normal, follow the steps below.
(1) Disconnect the negative battery terminal for 10 seconds.
(2) Connect the battery terminal.
(3) Turn the engine switch on (IG).
(4) Halfway open the power window by pressing the power window switch.
(5) If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time.
(6) Turn the engine switch on (IG).
(7) Halfway open the power window by pressing the power window switch.
(8) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 12 seconds after the power window is fully closed.
(9) Check that the AUTO UP/DOWN function operates normally.
Feb 05, 2017 | 2007 Lexus IS 350
GE Profile microwave oven PEB7226SFSS quit warming food but appeared to be on/operate with light on/timer counting down. Installed door switches-now the microwave "works" only when the door is open
Sounds like on reassembly you reversed wires to door switch.
switch might have letters C NO NC (common, normally open, normally closed) one wire goes to C common, the other to NC normally closed. Try reversing the wires.
If you use meter measuring continuity meter on C and NO should be high resistance until you press switch.
meter C to NC measures low resistance until you press switch then measures high or infinity (open)
Sep 28, 2016 | GE Microwave Ovens
Water keeps filling and wont stop
This is caused by a faulty water level control switch or a bad (or disconnected) hose from the outer tub to the switch. If you can give me your washer model number, I can be more specific.
Dec 23, 2014 | Washing Machines
How to disable tilt alarm on sportster
The bank angle sensor is on the motorcycle for a good reason and should not be deactivated in all normal operating circumstances and conditions. It operates with a conductive ball inside a case, if the bike tips more than 55 degrees from upright position the ball rolls sufficiently away to the leaned side from the bottom of the sensor in which case it either will connect two conductor points in a n/o switch arrangement and send a current to the ECM or it will roll away from two conductor points and break a n/c circuit and not allow current through to the ECM. If you want to test a bank angle sensor you would place a magnet on top of the switch which would cause the ball to move away from its normal resting position and thereby activate the switch similarly to a rollover of more than 55 degrees would do. You would need to place the magnet on top of the switch and then check continuity through the switch to ascertain whether it is normally open or normally closed. Then remove the magnet and do the same again, If it is normally open or if it normally closed then you can decide how it works. If it is activated then the ECM will not allow a start until the bike has been returned to the upright position and the ignition has been cycled off and on.
Jun 22, 2014 | 2003 Harley Davidson XLH 883 Sportster
Can you bypass the side stand switch
A side stand switch is just a spring-loaded, momentary switch.
What you have to figure out on yours is if it's normally opened, or normally closed (in electrical terms).
The best way is to use an Ohmmeter or a continuity tester.
Remove the 2 wire leads from the switch, and hook the test leads to it.
Pushing the plunger on the switch and watching the Ohmmeter gauge, or the continuity tester light, will tell you if it's normally open or close.
What you need to do is to replicate the reading when the plunger is in the same position as when the sidestand is UP.
The end results will be that (depending, again, if the switch is normally opened or closed) is that you need to either just disconnect the switch (having the 2 wire NOT make contact with each other), or connect the 2 wires so they stay in contact with each other (run a jumper wire between them, cut/strip/twist/solder the wires together, etc).
May 11, 2014 | 2002 Honda VT 750 DC Shadow Spirit
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
I have a 3 pole ( labeled A,B,C) switchcraft momen...
I suspect that you actually have a one-pole, two-position switch, with three terminals that are labeled A, B, C. If you have really do have a three pole switch, then it will have either 6 or 9 terminals. If you have three terminals, then the middle one is the common one, and A and C are switched - one is normally open, the other is normally closed. If you have 9 terminals, then the same thing applies, you just have 3 switches operated by one button (or lever or whatever). If you have 6 terminals, then again it's just 3 switches with one button - however all three of them are either normally open or normally closed. I hope this helps. Add comments if you need more help. Al K
May 21, 2010 | Electrical Supplies
My spacemaker just stopped heating food. What do
This is a microwave, correct?
I suspect the door lock interface switch(es) are burned out. Unplug it, be mindful of the 25,000 volts in the silver thing. Check the micro switches (look where the door closes on the top right side, probably) two positions, normally open or normally closed. check them for proper operation.
Micro switches are the most common of microwave failures because most of us open the door while the machine is running causing arc at the switch and burning up the little contacts.
Sep 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
3 wire white rogers zone valve operated by 2 wire thermostat any one have a wiring diagram?
It is technically possible use a 2-wire thermostat with a 3-wire zone valve, but you need a single pole, double throw relay like a fan control relay with one normally open switch and one normally closed switch. 2-wire thermostats only have one switch that is normally open. 3-wire thermostats have two switches......one switch that is normally open, and one switch that is normally closed. The fan relay lets the 2-wire thermostat simulate a 3-wire thermostat. It's possible, but usually it's easier to just get a 3-wire thermosts.
Sep 06, 2009 | Heating & Cooling
Bosch 24 in. SHU43 Built-in Dishwasher Logo
47 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
