Question about Cowon System iAUDIO A2 (30 GB) Digital Media Player
When I click on power the cowon start to do firmware upgrade, and then it get nuts for 4 sec and then its show picture of white cross into red ball, and then it shut down any soulotion?
2 Suggested Answers
SOURCE: cannot upgrade firmware in d2 cowon
Check this vid it helped me...
Posted on May 17, 2009
Cowon iaudio 10 frozen
Hi. I had problem like this, now resolved. My device is iAudio 9+ otherwise it's not matter.
You can find some solutions on the web but... maybe you can not do proper result first or second time. It comes because of some differences for so lot of devices.
I used this method.
How To Recover your Bricked J3 using Tcctool iAudiophile net Forums
Only one way working for me.
1. Prepare drivers and firmwares. Tcctool and Windows drivers for USB flashmode. Latest FW for your iAudio from Cowon Korea site. Unpack all files/folders into special directory in root of your Hard Drive (c:\COWON for example).
2. Boot your PC in compatibility with non-authorised hardware mode. Press F8 button when PC loading and choose Drivers signature disabled mode.
3. Turn off your iAudio with reset button. Press both M(enu) and VolUp buttons and boot on power. Screen doesn't fire but device standing up in flashmode. Connect USB cable to device, then to PC. On Windows Device Manager you must find new Unknown Device. Install drivers manually from your specific directory.
4. Run on PC new task CMD, e.g. terminal window. Change work directory to your specific, f.e. cd c:\COWON
Run execution tcctool.exe -d cowons9 "name of your FW file"(without quotes).bin
Attention, your FW file (iaudio9P_fw.bin for me) must be in same directory with executable tcctool!
5. After flashing your iAudio must be connected to PC immediately as USB flash device. So you must copy all firmware files (named *.bin) to root of your Cowon device memory. Then reboot, your player must updating firmware and working fine. If still no, try use tcctool to boot on once more, then reboot normally. Copying FW files again doesn't required.
Hey you don't give up!
Mar 31, 2014 | Cowon Iaudio 10 16gb White
Tip
How to Fix Blinking Power Light on Linksys routers......
If you have a blinking power light on the router try to turn off the router for about a minute then turn it back on again. If the power light is still blinking follow the steps below to troubleshoot the problem.
1.HARD RESET- Reset the device to factory default.
a.Press and hold the reset button for 30 sec., after that
b.Unplug the power keep holding down the reset button for another 30 sec.
c.Then, plug back the power keep holding down the reset button for 30sec., after that
d. Release the reset button.
Make sure that you have downloaded the correct firmware version for your router from the Linksys website at http://www.linksys.com/download. You would be able verify the exact version of your router from the sticker at the bottom portion of the router.
2. Connect your PC to port 1 of the router.
3. Assign a static IP to the PC:
To statically assign an IP address
Windows 2000 and XP:
1. Click start, choose Control Panel
2. Double click Network Connections
3. Right click Local Area connections then select properties
4. Select “Use the following IP address” then enter on the IP address type 192.168.1.45 Subnet mask is 255.255.255.0 then Default Gateway is 192.168.1.1
Windows 95, 98 and ME:
1. Click Start, choose Settings then Control Panel.
2. Double click network.
3. Highlight TCP/IP -> for your network adapter (Ex. TCP/IP->Linksys Etherfast 10/100 Network Adapter)
4. Click Properties
5. Select Specify an IP address then under IP address, type 192.168.1.45 Subnet mask is 255.255.255.0 then
6. Select on Gateway tab. On New Gateway type 192.168.1.1 and click Add. Click OK all the way until it prompts you to reboot the computer.
7. Reboot PC.
4. Force the Ethernet card of the PC to 10Mbps
To force the Ethernet Card to 10 Mbps:
Windows 9x and ME:
Go to Start > Settings > Control Panel>Network > Highlight the LAN card you are using with a green icon beside it > Properties > Advance Tab:
-Under Properties set the value of:
“Media Type”; “Connection Type” or “Speed and Duplex Mode” to “10mbps/half-duplex”; “10BaseT” or “10Mbps HD”.
Windows XP and 2000:
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Configure > Advance Tab:
5. Ping the router
a. On WinXP/2000:
Click Start > Run. On the Open field type cmd then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step
b. On Win98/Me
Click Start > Run. On the Open field type command then hit OK. On the DOS prompt type ping 192.168.1.1
If it replies 4 times, proceed to the next step.
6. Proceed in upgrading the firmware of the router.
7. After upgrading the firmware, power down the router and then power it back up and see if the power light is now steady.
To upgrade the firmware follow the steps below:
Access the router’s Web Base Utility [http://192.168.1.1]> Administration TAB > Click on Firmware Upgrade > Click on Browse > Browse or look for the *.bin file > click on OPEN > Hit UPGRADE button. (Just wait for the message “You have successfully upgraded the firmware”) > Click on the Continue.
After upgrading the firmware try to turn off the router for about 30secs then turn it back on again. Hard reset the router then reconfigure it to work on the Internet.
Hope this procedure works for everyone......
on Jan 04, 2010 | Linksys Wireless-G Broadband Router
After trying to update FW of my Cowon D2/4GB I've got just empty screen. When exploring I see 6 folders containing: MUSIC - empty; PICTURES - empty; RECORD - 4 empty subfolers; SYSTEM - 5 files:...
Hello there, what has happened to your unit is simply a situation of corrupt filing or an incomplete firmware update installation. When this situations arise it is considerably difficult to fix as the unit mostly does not initialize to start up the installation process to enable you re-install the fresh firmware. This problem is generic with the D2 as a lot of people have encountered the same problem. Best situation is return it back to the local dealer as this seems to be the best way out.
Hope this solution has been helpful?
Thank you for visiting FixYa.
Jul 24, 2011 | Cowon System Cowon D2 Digital Media Player
Ipod 80gb silver, when i turn it on it has a RED CIRCLE WITH A RED CROSS INSIDE ON IT AND UNDERNEATH THAT IT TELLS ME TO GO ON .... www.apple.com/support/ipod and i've tried this but it was no help. The...
connect the ipod to pc
start itunes
when it detects the ipod in recover mode
click on restore button to restore the firmware
it will download and reinstall the firmware
if it isn't detected in recovery mode then simply click on update button when it is detected normally in itunes.
Mar 05, 2011 | Cameras
I accidentaly foramatted the memory of Cowon D2 and now the computer does not even recognise it though it is connected via usb. I was trying to have latest firmware from cowon installed--mine is 2.50. My...
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer.
you your problem resolve ,don't forget to rate it
Jul 04, 2009 | Cowon System Cowon D2 Digital Media Player
Hey please please help me when i put my cowon a2 on it just shows the logo and then a red circle with a cross appears then it just goes off
Plz format your device by pluging it into computer... then it would get good as new and also you can recover your data by keeping back up or just recovering it from any software .. recommended DATA doctor recovery
Jun 23, 2009 | Cowon System iAUDIO A2 (30 GB) Digital...
CLUNKING NOISE FROM REAR AXLE
Problem I found: Clunk when driving over even small bumps.
If Grand Cherokee is 1999-2004, then check this: Above the differential is a wishbone cross member control arm. The cross member attaches to the frame in front of the rear axle (bolts through rubber bushings), and directly above the differential, at the apex of the cross member, is a ball joint. The ball joint assembly is a flange bolted atop the differential, with three bolts, and the ball joint pin protrudes from the flange through the cross member apex, with a nut atop the pin. Raise the frame slightly, and with a pry bar, pry above the flange, and below the cross member, very near the ball joint. If any motion is detected, then the ball joint is worn from the ball joint socket, or the nut is loose on the ball joint pin. If the nut is tight, then replace the ball joint. 2000 GC part number is 52088808AB, and is available from online sources or dealers. To replace this part, you'll probably need to remove the cross member, as the ball joint pin through the cross member is in a tight location, is tightly wedged into the cross member, and requires a special v-shaped puller to remove the pin from the cross member. If you don't have access to the puller tool, then remove the cross member for this operation. Raise vehicle slightly, under frame, in front of rear wheels. Unbolt the brake line and brake cable retainers from the cross member, then unbolt the flange from atop the differential. Then remove the two frame bolts and manipulate the cross member out of the vehicle, from above the differential.
With the cross member before you, support on blocks, loosen the ball joint nut somewhat, or remove it, and with a beater protective block, sledge out the pin from the cross member. Inspect the rubber bushings at this time. These bushings require an arbor press to remove/install, and the arbor press to install requires a spider so as to not rip the rubber bushing from either the bushing shell or center spool. The press spider is a 4-point tool you can make up from a piece of aluminum.
Bolt the new ball joint flange atop the differential, using blue thread locker, and torque the bolts to 100 ft-lb, cheater pipe useful here.
Replace the cross member to the frame, and install the two frame bolts, finger tight. Pull the member apex down onto the ball joint pin, and run the nut down. Using a box end wrench, hold the pin from rotation while tightening down the nut. Torque the nut to 100 ft-lb. Tighten the frame attachment bolts to 100 ft-lb, and reinstall the brake cable and brake line retainers. Do not over tighten these retainer bolts, as they are passing only through the sheet steel side of the cross member. Take care to not strip the sheet metal threadings. Lower vehicle and remove jack.
May 15, 2008 | 2000 Jeep Cherokee
White sreen and wouln't charge
I would recommend you to try to reset the player and then get a firmware upgrade...to reset the player you need to hold down the power buttom for 15 to 25 secs...
to get to the firmware upgrade go to
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
If for some reason after you have reset the device and get the firmware upgrade your device is not working you can try to use the recovery tools...
I hope this help...
Thank you
Computerrep
**Please rate accordingly**
Jan 28, 2008 | SanDisk Sansa e250 MP3 Player
Cowon System iAUDIO A2 (30 GB) Digital Media Player Logo
Top Cowon System Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cowon System Audio Player and Recorder Expert? Answer questions, earn points and help others
