Question about Palm Pixi Cell Phone
My phone only vibrates but doesn't play the ringer but when my alarm comes on it does
  • 358 Answers
Hi, since you said the phones alarm work that means the phone ringer works.I think you need to check the settings of the ringer. I think that will do.
Take care.
Posted on Oct 01, 2010
2 Suggested Answers
  • 490 Answers
SOURCE: Ringer problem
If u r able to play ringtones it means settings are improper.U have to consult the manual of the handset or just visit service centre in case the  problem persists.
Posted on Oct 20, 2007
Ringer jumpering
Try using or get a new ringer does the vibrate works?... You can find ringtones on google play store
Oct 16, 2013 | Samsung S5620 Cell Phone
Vibration works and ringer doesn't problem with samsung sph-m540
If the vibration works the circuit is working OK. All what can be done is to reset the phone , remove battery and reset, check for any corrupt files on the memory card. Now open settings, tones and check the default settings. check tone set and tune selected. Now if there is no result the ringer might be open and faulty. You can check the continuity to confirm , if so replace.
Sep 27, 2011 | Samsung SPH-a460
My phone doesn't ring or vibrate also the speaker doesn't work
Hi,there are three things you need to check..
The vibration..
The ringer...
The flex....
Hi, what makes nothing happens even when trying different levels of the vibration is because the ******** of the phone that makes the phone vibrate when someone calls is damaged.
You need to replace the ******** before it will respond again. It is located inside the phone,always round in nature.
When replacing the ******** of the phone,you have to be careful when unscrewing the phone screws.
Get a phone screw, unscrew necessary screw off, take the back cover off locate the ********, (round like the ringer)But the difference is clear.Go to any phone repair store around your area and purchase another phone by tell them the model and make of the phone.
After replacing the ********, screw back the screws and your done.
Would advice, if no knowledge about phone repairs, please contact a skill full personnel for help.
What causes phones not to ring out is when the ringer that makes you hear a tone when someone calls is damaged and does not work properly again.
The ringer is located inside the phone.You can get access into the phone by unscrewing the phone with a phone screw. It a little bit technical when unscrewing the phone.Just be careful not to damage the phone.
How to unscrew the phone.
Remove the back cover of the phone where the battery is,
then remove also the battery, at the edge you will see where the screw are located.(look closely).
After unscrewing,the screws, Open from the size of the phone,you will see where the ringer is located. It's usually round in nature. Remove and cover up the phone. (you can get a replacement ringer from any phone repair and sale of part store around you.
Ones your through with the ringer , 'wa la' Your done..
Note:if you can't loose the phone, in other not to cause damage to the phone,please contact a skill full personnel for assistance.Thanks.
Before you replace it,you can also clean up the ringer ,there might be dirt stopping it from working properly.
Hope it helped......
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone and also the ringer and vibration...
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Jun 16, 2011 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
Hi! i just bought a lg-ks360 and i don't know what to do! i just can't hear the phone ring when i get a call or a text message. i tried using the alarm clock and it was useless, i just didn't hear it ring!...
You may just have the phone's ringer at a very low volume or on vibrate. Just raise the ringer volume and you'll be able to hear everything. If you're listening to a mp3, pause it and try to raise the ringer volume.
Apr 30, 2011 | Cell Phones
Sir, nokia model 2626 Ring tone sound not coming when incoming calls comes speaker option is function all ringtone sounds comes only vibration please solve it thank u
The ringer is gone bad. Go to service center and just ask them to change the ringer. It will cost less than 100 rupees.
Make sure the phone profile is not in silent or in vibration only...
Apr 19, 2011 | Nokia 2626 Mobile Phone
VIBRATE STAYS ON
Follow the below instructions and you can remove the vibrate state. I have included a link to download the phone's manual as a PDF file.
Sound Settings
Ringer Types
Ringer types help you identify incoming calls and messages.
You can assign ringer types to individual Contacts entries,
types of calls, and types of messages.
Downloaded Ringers can be downloaded right to your
phone.
Preprogrammed Ringers include a variety of standard
ringer types and familiar music.
Vibrating Ringer alerts you to calls or messages without
disturbing others.
Selecting Ringer Types for Voice Calls
Your phone provides a variety of ringer options that allow you
to customize your ring and volume settings. These options
allow you to identify incoming calls by the ring.
To select a ringer type for voice calls:
1. Select Menu > Settings > Sounds > Ringer Type >
Voice Calls.
2. Select With Caller ID or No Caller ID.
http://downloadcenter.samsung.com/content/UM/200708/20070824101259031_sprint_m300_ug.pdf
Mar 19, 2011 | Samsung SPH-M300 Cellular Phone
How do I adjust the volume on the alarm feature of the LG Quantum phone
The alarm plays at the same volume the ringer is set at, put it on loud before bed if it doesn't wake you up. Weirdly you can even set the phone to silent after making it loud, that way wont wake you if you get a text/email during the night.
Mar 06, 2011 | LG Quantum (16 GB) Smartphone
BlackBerry Storm 9530 will not ring
It seems like the problems starts after using an audio streaming app (Slacker)It also seems to correct after a reset(battery out and back in).
Feb 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
Ringer problem
Oct 10, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Palm Pixi Cell Phone Logo
159 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
fhonwizards
wayne chamberlain
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
