Question about Kenmore 17459 Free-standing Dishwasher
Snap on fitting no longer stays on faucett
Our kenmore portable dishwasher was working fine more a couple months but now the snap on fitting keeps popping off during the cycle spraying water all over the place. It seems the small white plastic things on the inside of the head are stripped. Is there a way to replace just the head part of the hose instead of replacing the entire hose?
  • 2 more comments
  • Anonymous Jul 01, 2008
    We are having the same problem! Have you found anything out?
  • chairie Jul 17, 2008
    yes maytag wont stay connected to faucet
  • jannfey Aug 23, 2008
    Same problem. Any solution yet?
  • Anonymous Nov 26, 2008
    Kenmore portable Dishwasher Model# 665-1784200
    Only 2 years old and the "LOcking Collar"on the Faucet adapter keeps pottin off during the water cycle spurting water all over the place.I paid $69 to a local appliance repair person and he wants anothe $89 for the collar assembly and to install this assembly another $90 to disaaaemble the cabinet and disconnect the old and install the new Coupler assembly,part# 3378117.What a waste of time and money.Four tiny white plastic knobs are probably slightly wore enough so that they slide off the locking collar.If there was a way to replace the tiny plastic parts,the repair job would be very simple and for a do-it your-selfer the cost would be under $5.00.
    Is there a way that I could replace the tiny white plastic parts myself?
Go to www.searspartsdirect.com and you can search by your model number for the dishwasher or any other kenmore part. The schematics magnify as you mouse over them and then you can scroll down to see the matching part number. The part 3378117 is the whole hose assembly including the faucet coupler and the full length of the hoses. Notice that the part number 3378117 has been substituted with W10217197. When I Googled for "W10217197 dishwasher" there were a number of vendors selling that part including ApplianceZone.com selling it for $20 less than Sears and other vendors. Unfortunately the way the faucet coupler is crimped onto the hoses you have to replace the full length of hose [not just the coupler] but I have a problem that requires the whole hose. I've opened the cabinet up - which required a star headed driver - and from there it's just a matter of removing basic connectors inside the box.
Posted on Nov 04, 2010
  • donovanr6 Dec 21, 2010
    http://www.searspartsdirect.com/partsdir...
    Just the 4 nylon parts. around $20.
    part number wp-285170
    or search 285170 kenmore
Actually I have that problem as well. Yo do not have to replace the entire hose assembly. There is a small kit you can buy that is called "Collar AW" that you can get from any appliance parts store. There is also a part number but I do not have it in front of me right now. The kit is usually around $20-$25 and includes 4 new "teeth", spring, head and locking C-clamp. They usually only last about a year or so but it is cheaper than buying a whole new hose assembly and having to tear apart your dishwasher to assemble it. I will find the part number and post it shortly. Hope this helps.
Posted on Feb 15, 2012
  • 2 more comments
  • Chris Feb 16, 2012
    The label on the package I bought is from FSP Part number 285170 labeled "Collar". Call up any appliance parts store and they should be able to order it for you. As I said earlier, it costs about $25.00 or so and seems to only last about a year before the "teeth" give out again. You also might want to replace your dishwasher snap adapter (screws on to your faucet) periodically because it wears out as well and that is what the "teeth" grip on to. They are usually around $5.00 or so. Better than replaceing the entire hose assembly. Hope this helps!
  • dbearylove
    dbearylove Jan 29, 2013
    how do you just replace that part? I am getting ready to order one, but before I do, I need to know how to fix it.
  • Chris Nov 18, 2013
    You need to depress the collar. Once you do, you will see a thin C clamp. Remove the clamp and the collar, spring and teeth will come off rather easily. replace the teeth (you may have to hold them in place)put on the spring and then the collar. Depress the collar and put on the C clamp. That will hold it all together. You may want to replace the snap adapter on the faucet as well as it wears out too.
  • Chris Sep 10, 2015
    One other thing:Sometimes the new collar wont fit correctly back on to the assembly (Wont depress when trying to put the c-clamp on.) Just use the old collar if this happens.
No matter what cycle the dishwasher runs, the glasses always have stuff stuck to them. have run a couple of different washer cleaners through it but no luck .heating elements are fine. any suggestions
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Sep 14, 2010 | Kenmore Dishwashers
I need a new faucet adapter for a Kenmore Ultra Wash Portable dishwasher 665.17799990 to connect to a utility sink. Where can I locate this product?
the adapter i got with my new kenmore dishwasher does not fit with my kolher fauset. The sears serviceman said i need a longer adapter. I can't find one anywhere.
Jun 12, 2010 | Dishwashers
Kenmore portable dishwasher not performing.
There are likely more pieces of glass in the impeller of the motor keeping it from turning. It will have to be disassembled and cleared.
Eric
Jun 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Adapter for Kenmore 17669 portable dishwasher
Hi, Please get me the model # from the label inside the door openong and I will look this up for you.
Vic
May 28, 2009 | Kenmore 24 in. 17669 Free-standing...
Portable Dishwasher
I sent you and email with some instructions, Look to hear from you soon!!
Mar 25, 2008 | Kenmore 17252 Free-standing Dishwasher
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Door will not stay closed
you should take it back where you bought it and exchange it for another one.
Nov 07, 2007 | Durabrand Portable DVD
Soap door won't open
The rinse aid compartment on my Kenmore Portable dishwasher ( Model 17829) leaks and doesn't hold the solution. It seems to have done this for longer then I can remember. What can be the problem?
Sep 21, 2006 | Kenmore 17252 Free-standing Dishwasher
Kenmore 17459 Free-standing Dishwasher Logo
2,380 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
