Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
I need suggested setting for temperture control
    Brigadier General:
  • 3,513 Answers
Please check the links related to your query:-
http://www.ehow.com/how_5000665_set-refrigerator-temperature-correctly.html
http://tlc.howstuffworks.com/home/question121.htm
http://www.wikihow.com/Set-Your-Refrigerator-Temperature
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 01, 2010
Set thermostat at 74 heat pump will not cycle it will cycle at 75 degrees ?
check stat calibration. see if you can measure temperture at stat. the thermostat cover temperture reading is not that accurate.
Jun 01, 2014 | Goodman CLQ36AR49 Air Conditioner
Where is air shutter adjustment
On you fan control, Controls the speeds, End your temperture cotrol controls hot end cold setting, You don,t have shutter controls in a vehicle,
Nov 03, 2012 | Cars & Trucks
Where is the temperture control system
some model has not display temperature control system.
You must see your instruction manual for indicate how to control the temperature. if you do not have download www,fitness.manualsonline. com or www.retrevo.com or www.manualsfactory.com
God bless you
May 09, 2012 | 2005 Chrysler 300 Hemi
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
The car keeps coming up a code 23 on a 1999 chrysler 300 for the
Code 23= Blend door feedback control
On cars with automatic climate control: To enter diagnostic mode, set the temperature to 75F, press the the off button. Press Floor, Defrost\Floor, Front Defrost simutaneously for 3 seconds until the temperature display begins to flash.
On cars without automatic climate control, set the blower to any speed, turn the temperature control in between warm and cold. Press Floor, Defrost\Floor, and Front Defrost. All codes will flash via the Front Defrost button.
When the test is over all fault codes will be displayed (on cars without automatic climate control, they will be blinked out on the Front Defrost button).
Code Action
23 Blend door feedback control
24 ATC mode door feedback failure
25 Ambient temperture sensor failure
26 ATC in-car sensor
27 Sun sensor failure
31 ATC recirculate door stall failure
32 ATC blend door failure
33 ATC mode door stall failure
34 Engine temperture sense failure
35 Evap temperature sense failure
36 ATC head command failure
Mar 23, 2009 | 1999 Chrysler 300M
The problem is with the heater.
3 words come to Mind. Heater Blend Door
Mar 17, 2009 | 1999 Ford F150 Regular Cab
Heating system
it is the control module u set for heat/ac in the center of the dash, all the electronics are in side this module that do the switching and maintain the temp u set
Jan 12, 2009 | 1996 Buick Roadmaster
Siemens RDE20.1 upper temperture setting
Hold the return and + button at the same time for at least three seconds, then adjust the indicated temperature down which tricks the thermostat in heating to a higher temperature before the set point is reached.
Dec 09, 2008 | Siemens Efficient Networks SpeedStream...
TOW FANS AGAINST THE RADIATOR, TOYOTA CAMRY 2001 4 CYL
yes, they are both radiator fan. dependent on the temperture of the outside air and the cooling temperure on control panel. the fan will kick on when the temperture cross over the preset- set on the computer. so, either fan on, no fan, fan is runing when the car is runing or not, is not a porblem.
the porblem occures when the fan stops, and the temperture is over 100 degree outside.
Nov 11, 2008 | Compaq Presario 1626 Cooling Fan Case...
High temperture
Have you check the thermostat?
You might want to remove it and install a new one see it still overheats.
May 27, 2008 | 2006 Chevrolet Cobalt
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
96 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
