I need my wifi security phrase.. or wpa thing
  • 127 Answers
Is it a case your trying to use a wireless connection in your house if so what would your router make and model be (eg netgear)
Posted on Oct 01, 2010
Can i change my wifi password ..casue i forget it
Hi Jeanine,
Yes, you can change your WiFi security key / pass phrase. Log into your router - many are on one of these addresses: http://192.168.0.1/ , http://192.168.1.1/ or http://192.168.2.1/ . You'll need to supply your username and password when prompted.
Once logged in, click on "Wireless" or "Wireless Security" to make changes to the wireless security type (Open, WEP, WPA, etc.) and the security key - among other settings. Be sure to save the settings before you exit out.
If you can't remember either the address, username or password to log in - you'll have to do a full reset by holding the reset button for up to 30 seconds or so and then redo all the settings from scratch. Check your Router / AP documentation or manufacturer's support pages for this information.
Oct 20, 2014 | Computers & Internet
Belkin.4f6 wpa key
LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
Apr 02, 2014 | Belkin Computers & Internet
How do I prevent my neighbor from using my wireless router?
If you do not have any wireless network security enabled on the router, your neighbor can see this SSID and connect to the network without authorization. While this is generally frowned upon as being unethical, it is technically not illegal as you have "made the network available" by failing to secure it. The easiest way to secure the network is through the use of a WEP key or a WPA pass-phrase. WEP keys are generally 5, 10, 13 or 26 randomly generated characters long. WPA pass-phrases are just that - a phrase such as "The sun is yellow". Either method will prevent unauthorized users from accessing your network. Only those individuals who possess the key or pass-phrase are granted access.
These options is located under the Wireless > Wireless Security tabs from within the router administration.After login you can change the password.
If you need any kind of technical assistance you can contact support cell at here
Jan 22, 2013 | Belkin Computers & Internet
How do I block other users from using my Modem
you need to lock the wifi use your house or cell phone number as a WEP key
Mar 02, 2011 | Arris SURFboard SBG900 Wireless Router...
How i can setup Wifi to Thomson (DCM305R) modem?
Hello, Thanks for the opportunity to help you.
First off you modem there is not wifi but cant be hooked up to a wifi router that you can purchase from any computer store.
The modem would hook up to the router directly instead of hooking to the computer via RJ45 "ethernet cable"
The wifi router would then share that connection. You would need to set that up with some security I recommend WPA 2 encryption you will need to select a password/ or pass phrase.
In order for me to give you the How To's we would need some more information such as:
1. Brand name of router
2. Model number
Click here for some basic information on how to hook up a cable modem to a wifi router.
Thanks for using Fixya.com , We hope your found this Very Helpful.
Jan 25, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
What is wpa or wep
It is the security code that is setup on the router to prevent an unsecure network
Dec 08, 2010 | Belkin F5D7234-4 Router
How do i make a password on my wifi conection..my router is linksys BEFW11S4 v.2
First, your router is old, go pickup a new one that supports the G standard, don't worry it will fall back to B standard or better yet get an N standard router. To setup wireless security directly connect a pc via cat5 data cable to one of the switch ports on the router (not the wan) and login to the web innerface, click the wireless tab, now look for the security or encrypted options. Most routers support WPA-2 encryption where you enter a phrase of 2 or 3 words if your router only supports web encryption go buy a new router. Save it, then go to your pc, disconnect, remove the wifi ssid from your managed wireless list refresh and search for the ssid of your wireless signal (name), now connect and the router should challenge you for your WPA pass phrase you setup in the router. Now your wifi ssid is secure and all connections will require the passphrase.
Aug 28, 2010 | Linksys BEFW11S4 802.11b Wireless...
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
What does it mean entering the encription key of the access point being connected?
If your player is connected to the internet then you need to check your wireless router. You could first try power cycling the router by unplugging the power cord from the back of your wireless router for 15-30sec or get a paper clip and hit the small reset pin hole on the back of the router. If your still getting this message then you need to find out what wifi security phrase or code is on your wifi router either you have WEP or WPA-PSK security code for your home network. The access point is your wireless router or Modem. If you do not remember or have the passkey then you need to contact your internet router/modem manufacture.
Apr 25, 2010 | Panasonic DMP-BD10 Blu-Ray Disc Player
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
