Question about Yard Machines 46" Tractor Mower Blade Kit OEM74204290
Can't get the lawn mower in neutral. Can't move the machine when it is not running.
John deerf525 lawn mower . Put it neutral to push it now when it is running it won't move. Still in neutral
on some of the mowers to push it you have to pull a lever in the back that disengages the transmission. make sure it is pushed back in the operate position. also if not hydro stat . check the belt to be sure it has not came off.
Sep 16, 2016 | Garden
How do you push a toro riding mower
riding mowers have a bypass system to be able to move a machine that's not running. At the rear of unit you will find a heavy wire coming out the back end lift a little and pull this out. you should now be able to push unit
Oct 18, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Stuck in gear
I'd go to the junction of the linkage and the transmission and check from there. The transmission will have a lever or some sort of protrusion connecting to the linkage. See if you can move the lever/protrusion by hand, even if you have to disconnect it from the linkage. If you can move it, try to find neutral and reattach the linkage and adjust it so it corrresponds to the indicator on the shifter. If you can't move the lever/protrusion it's internal to the transmission and you are out of luck unless you're up to cracking open the transmission.
May 10, 2014 | Yard Machines 155 Torque Briggs Stratton...
My Weedeater riding lawn mower will not move when it is in drive or reverse
Check your drive belt that it has not slipped off the drive cog under the motor. Also check the alignment of the motor with the handle on the right side (speed, reverse, and neutral lever).. This lever tilts the engine to engage the drive belt.. there is no transmission in this machine.. just how the belt engages by its angle when you push the lever forward and backward.. If the engine is running, it must be either the belt to drive the unit or the angle has been messed up somehow..
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
HYDROSTATIC TRANSMISSION NOT WORKING ON NEW MOWER
there is a rod on the rear of the mower that is pulled back and lock into place this is there to push the mower around when not running it just lift the lever up and it should pull in then your ready to go
Sep 02, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Wheels are locked cannot move in neutral
If, t's a Craftsman You might can go to rear of your Mower and Release the Freewheel Control Level.
Nov 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When stoping lawn more and moveing the control levers out ward the right brake is not holding. the mower starts moveing to the left. Can you give me some idea what i need to do to fix this. Thank...
they're is an adj at the pump follow your arm linkage down to the pump, with it running you adj it one way or the other to get neutral out of pump, then try it and tighten everthing up
Apr 06, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
When i put mower in reverse it moves very slow an when in neutral mower still moves forward have to pull lever back beyond neutral position to find neutral is there an adjustment on transmission
yes
there is a adjustment under the r/h rear gaurd just under where the lever goes to hydro unit you should see a slot and a adjustment bolt arrangement
make sure you put the tractor in true nuetral 1st then undo the bolt that clamps lever to shift arm / shaft ( this connects to plate that operates swash plate on the pump ) and move the lever either fwd or back until (without moving transmission from true nuetral ) it fits into the nuetral slot correctly and tighten the adjustment bolt - test and adjust as nescesary
here is website for parts
http://www.outdoordistributors.com/Craftsman/Craftsman_Search.html
get model and type numbers off machine ie 917-??????
here is web site for parts
Aug 09, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a LT 1024 series 1000 Cub Cadet lawn mower. The PTO shuts off when I'm mowing the lawn. It will run ok if I use the cruse control. I was told it might be a motion switch. Where is this motion switch...
There should be 3 safety switches on the mower. 1 will be under the seat, causing the engine to die if you were to fall off the machine while in gear. 1 is in the transmission to be sure the machine is in neutral when you go to start it, and one will be on the blades to insure they are not engaged when you go to start it. You will not want to bypass this switch, rather get it replaced as it is very important that this safety feature is working should you slip off the seat or accidentally get off the machine when it's in gear.
Feb 17, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
Yard Machines 46" Tractor Mower Blade Kit  OEM74204290 Logo
112 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
