Question about HP Computers & Internet
How do you put in ink cartridges into the printer
    Scholar:
  • 187 Answers
Depends on the printer. If it's the "all in one", then usually you'd lift up the lid + scanner to get access. For the older and single function printers, you'd lift up the access flap. The holder for the catridges will position themselves so they are accessable. Which printer do you have?
Posted on May 26, 2008
The printer keep asking for ink replacement. the cartridge ink is half full. how can i use the remaining ink if the printer wants to replace a new ink. plz help
You take on the cartridge and you get the cartridge into the printer to put a mid-trough, where they see the chicken trough of ink cartridges.In the middle of the cartridge put tape and the printer see the cartridge full and you can use the remaining ink.If i have been useful please give me a vote :).Thanks
Apr 13, 2011 | Brother MFC 240C All-In-One InkJet Printer
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Put new ink cartridge in Epson NX 110
I have a epson stylus NX110 Printer the ink cartridges will not stop so that i can put in new ones.I press the stop button but the ink cartridges will not stop onthe arrow so that i can put in all new ones.
Apr 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
How to clean cartridge
Once you remove the ink cartridge from the printer, you can make use of the Isopropyl Alcohol, and put at maximum of 10 drops in the ink cartridge. You will find a hole there, in which the ink usually runs from the ink cartridge to the head of the printer. When done, you can put the cartridge back in the printer and run the auto cleaning process from the printer's option in order to clean the blocked holes of the cartridge. I would suggest you to run print tests first and once you are satisfied with the results, you can start using the printer normally.
If you want to go further:
  • Remove the tank.
  • Connect a hose directly on the inlet ink.
  • Locate the sensor of reservoir and press it to make as if a cartridge is available.
  • Close the cover of the print head and clean the head by injecting air (under pressure) through the pipe.
  • Replace the tank up and do a test print.
  • Repeat the procedure several times if the nozzles are clogged.
Using a syringe and some alcohol to unblock the holes can also be very effective.
  • Step 1: Remove the cartridge from the computer
  • Step 2: With the syringe, take in some alcohol and put in some drops in the tiny hole where the ink runs from the ink cartridge to the head of the printer.
  • Step 3: When done, put the cartridge (only where the tiny holes are found) in some warm water. If some ink runs in the water, it means that the holes have been unblocked.
  • Step 4: Hence, let the alcohol act for 20 minutes on the ink before putting the cartridge back in the printer.
  • Step 5: Run some test prints before using the printer normally.
Note: I would suggest you to do an automatic head cleaning each time before any printing task. Hence it will reduce the risk of having the print heads blocked by dried ink.
Apr 03, 2010 | Lexmark Inkjet Z517 Photo Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
R 340 cartridges have remaining ink but printer
just go to the process of ink cartridge replacement without actually putting in new ink cartridges, sometimes printers make read errors, just make sure ink cartridges are placed properly to position.
Jan 17, 2010 | Epson Stylus Photo R340 InkJet Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have put in new cyan ink cartridge but printer does not recog
are you sure you got the right ink cartidge put in? Also check if you took that piece of plastic that coverred your ink cartridge contact
Mar 20, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
Computers & Internet Logo
15 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
