Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
It shows only 2 bars of performance. The suction is minimal. I don't see a blockage, the filter is cleaned and it has a new bag. The vacuum is eleven years old. Can it be fixed or do I need to replace it.
  • 171 Answers
Depending on the brand of machine its a call you have to make . If it is a dept store machine I would recommend replacing it as the brushes in the motor are most likely worn out. Anyways I would go to local vacuum shop and inquire about a re furbished high end vacuum.These are the kind they sell in in home presentations.they start at 2500.00 but you can pick up a refurbished one for 300 to 1000 depending on your budget.I would recommend a Tri-star vacuum.They are small ,very powerfull and have a 30 foot cord(very convenient).lastly they are metal though they are light and extremely durable......good luck!
Posted on Oct 07, 2010
Why is suction substantially reduced?
blockage in the suction line
if it is the wet mode there should be a valve (ball) that sucks up to stop water from getting to the motor when the receiver is too full. If you are in wet mode and still have the dust bag in place then the bag will be a solid block of mud and that will be the blockage.
May 21, 2015 | Craftsman 17765 Canister Wet/Dry Vacuum
A smell like burning rubber comes out of the vents whenever it is used. It starts as soon as the vacuum is turned on. I've emptied the filter, but maybe I need a new one? I don't think the suction...
Hi sevillekathe...
The problem is that you have is that hair,strings,etc has gotten wrapped around the beater bar of the vacuum and it is trying to slow down the motor but the motor will not slow down so the smell you smell is the belt burning up because it is slippling and creating smoke and smell
You will need to remove the beater bar from the bottom of the machine and clean the hair,strings,etc from around the bearings on each end of the beater bar.
Also check your filter bag, check the hose going to the vacuum if you have one for blockages, and once you have the beater bar off check your belt condition and look for blockages going to the bag.
Please take time to rate me
Aug 30, 2011 | Dirt Devil M083405 Versa Power Stick Vac...
My fuller brush household canister vacuum doesn't have as much suction as usual. I've changed the bag and cleaned filter. Any other ideas?
. Test the suction without the pipes to confirm that the motor is sucking strongly, then check that there are no blockages in the pipes and fittings.
Jan 29, 2011 | Fuller Brush FBPTCAN Bagged Canister...
Eureka Rally 2 had great suction the first two times I used it and now faint. No blockage and new bag and clean filter. What coud it be?
The dust bag holder is an important part of this vacuum. Make sure the bag is installed into the holder sliding bag collar into slots to secure.
Make sure the bag is tucked into cleaner. or the bag cover will not latch securely.
Also, the motor and exhaust filters should be cleaned at each bag replacement.
REPLACING THE FILTERS
Filters should be cleaned or replaced when they become visibly soiled or suction power is reduced. Always operate the cleaner with the filters installed to avoid motor damage. The dust bag must be changed and the filters cleaned or replaced if the window of the Clean Filter Indicator changes into red when the cleaner is operating at maximum power and the nozzle is raised from the floor.
Dec 25, 2010 | Eureka Vacuums
This vacuum keeps getting clogged in the hose and has terrible suction. The women who helps clean my house won't even use it as it performs terribly. Any suggestions
check vac air filter(not the dirt collection bag) also something could be lodged in hose mechanism so there is always a partial restriction. make sure the beater bar is not set too low. check the dirt that accumulates in bag to see that there is not an excess number of carpet fibers in there. beater bar should be clean and spin freely.
Oct 10, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Jan 26, 2009 | Kenmore Vacuums
Lack of suction
I use a broom handle..works very well
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Performance indicator light
check to make sure the bag isn't being sucked into the air filter. open the access door where the bag is and you'll see the air filter at the bottom. to check, leave the door open while you would see the performance indicator light on, and then pull up the bag. this is one of many solutions i'm sure to the performance indicator problem.
Oct 17, 2007 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
