Question about Samsung SC-DX103 DVD Camcorder
My SD card reads card blocked in the cam and write protected on my computer. what can i do ???
    President:
  • Samsung Master
  • 1,932 Answers
To remove write protection see the below video
http://www.youtube.com/watch#!v=Be_aHSlDFCU&feature=related
Thank You
Posted on Oct 01, 2010
I CANT SEEM TO PULL PICS OFF SD CARD
A) Please don't shout.
B) What method are you using to transfer the images to your computer ?
Jan 05, 2017 | Cameras
Please Help
hmmm you should try the followings:
First insert your SD card and try to make a copy of your pics from camera memory to your SD card. And then use this SD card to your computer.
Or Using Camera manufacturer and model no. search some driver and software for you so that you can transfer the pics to computer.
if still not fix, let me know your manufacturer and model no.
Thanks
iqbal
Mar 23, 2008 | Samsung Digimax S630 Digital Camera
How to reset the password memory card
Transcend??
Mini SD cards, or MicroSD cards, are used in digital cameras and portable media players to house digital media files.
MicroSD cards can house anything from 2GB to 32GB of information.
A write-protection feature gives the owner the ability to lock the MicroSD card to keep their files secure.
If you have a MicroSD card that is write-protected, you can un-write-protect it with a flip of a switch.
Insert your MicroSD card into the adapter that came with it.
Put the data side of the MicroSD card into the data side of the adapter.
Look for the write-protection switch on the left side of the SD adapter.
Flip the switch to the side that reads "Off."
Remove the MicroSD card from the adapter and replace it in the device you were using it with.
or you might
Feel along the lower right and left sides of the Micro SD card to find out if it has a built in write protection switch.
Move the switch over to the "On" position to turn on the write protection feature.
Check the front ports on your computer and see if it already has a built in card reading unit.
Purchase an external card reader that plugs into a USB port if your computer does not already have an internal card reader (see below).
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=card+reader&x=0&y=0
Plug the card reader into any open USB port on the computer.
Power on the computer and let the operating system finish loading.
Insert the card into the Micro SD slot on the card reader.
Wait for a new window to appear that will ask what action you want to take with the Micro SD card.
Click on the link that says "Open a folder to view files."
Right-click on a file if there is just one specific file you want to enable write protection for.
Click on the "Properties" link from the menu that will pop up.
Navigate to the "General" tab.
Click on the box marked as "Read Only" and then close the Properties window.
Close the window and then double-click on the "My Computer" icon on your desktop if you want to enable write protection for every file on the Micro SD card.
Right-click on the name of your Micro SD card in the list of computer drives.
Click on "OK" and then close the window.
Click on "Properties" and then navigate to the "Security" tab.
Scroll down to the heading labeled as "Permissions."
Click on "Deny" under the "Write" section.
or
Slide the switch on the left-hand side of the SD card. If the switch is broken, proceed to Step 2.
Affix a small piece of tape or paper to the top half of the gap where the slider should be. Do not permanently affix the paper as of yet. 3
Try the card in your computer, using the USB converter stick.
If the items on the SD card are available, copy them to your computer as a precaution.
If that did not solve the problem, proceed to Step 4. 4
Remove the tape or paper and reattach it to the other side of the gap if you mistakenly attached it to the wrong side.
If you are actually trying to unlock a micro or mini SD card, proceed to Step 5. 5
Toggle the switch on the left side of your SD Adapter if you are trying to unlock a micro or mini SD card.
Micro and mini cards do not have switches.
Instead, insert a micro or mini card into an unlocked SD Adapter to work with stored data.
SD Adapters look very much like SD cards and the switch works the same way.
Nov 26, 2013 | PNY 1GB microSD Memory Card
Pny sdhc card protected
or you might
Click on "Properties" and then navigate to the "Security" tab. Scroll down to the heading labeled as "Permissions."
Nov 23, 2013 | PNY 4GB Secure Digital High Capacity...
Where do I go in the system to set the default storage to the sd card?
SD storage card restore to defaults
Click start click to open on my computer you should see your usb drive F: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Take Off Write Protection on an SD Card
Secure Digital (SD) flash memory cards are a common storage format for mobile devices.
By default, they allow both reading from and writing to the card.
However, they can be set so you can only read from the cards and not write to them.
Some cards are created as read-only by default.
Other times, a faulty card reader may mistakenly read all cards as read-only.
In both cases, you can make simple changes to the card to disable the write protection.
1.
Orient the card so the label is facing up.
Slide the write protection tab, which is located on the left side of the card, to the unlocked position.
If there is no write protection tab, skip to Step 4.
2.
Test the card in your computer.
Insert the card in the SD slot and open the folder to view the files.
Try to save a file onto the card or right-click an existing file and select "Properties," then uncheck the box marked "Read-only."
3.
Remove the card and check to see the write tab is still set to "unlocked" if you get a message that says it is still write-protected.
If it has become locked again, slide it back and tape it in the unlocked position.
4.
Place a piece of masking tape over the notch in the SD card located on the right side of the card. Make sure the tape does not cover any of the card's metal contacts.
Test again as in Step 2.
5.
Cover the notch with a second layer of tape if the card is still giving you problems.
http://www.getflashmemory.info/hack-why-is-my-sd-card-write-protected/
Aug 15, 2013 | Avatar Sirius S701-R2A-1 4GB NAND Flash 7"...
My olympus cam t-100 Showing d error of write protect, actually i was replace my card last nite from my cell to cam or i can also delete all pics from cam. how can i recover back same like before i do
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 27, 2012 | Olympus "T-100 - Digital camera - compact...
Computer reads sd card as right protected when unlocked
Check that the little tab on the card is all the way forward, toward the contacts or removed completely.
Try another card to see if you get the same condition.
Try the card in another computer or another card reader.
Check out the link bellow
How to Remove Write Protection on an SD Card
Dec 11, 2011 | HP Pavillion s7420n PC Desktop
My memory card is full so I can't take more pictures. I want to delete the old ones which are saved somewhere in the disk but it only shows the old pics in the camera, only when i put the memory card...
If your memeory card is a SD card then -
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.You can then delete the phots using your computer OR format the memory card using the camera.
Jul 15, 2011 | Computers & Internet
Computer and camera does not read SD card even though it read a couple hours ago
If it comes up w. fault mgs then try on a comp.
If nothing
Try dif. USB opening
Try dif cable
Try dif. cardreader/cam.
Your SD card can be faulty. If the computer reads a dif. card. Then ;( you might have to re-format.
Nov 11, 2009 | Cameras
PNY Optima 2gb SD Card Write-Protection Problem
Ur right it has a physical problem. Try to format it using dos and then give it a try.
Thankyou
Jul 31, 2009 | Electronics - Others
Samsung SC-DX103 DVD Camcorder Logo
149 people viewed this question
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
