1998 honda civic, starts and runs once I shut it off and try to start again it just spins and will not catch after about 15 20 min. it will start again, what might the problem be?
Re: 1998 honda civic, starts and runs once I shut it off...
It sound like you have a bad relay. Its getting hot and has to cool before your car starts. Its probably the EFI main relay.For a guide on checking the relay CLICK HERE
Need way more information. What's in common when this hapopens? Are you stopped at a light? Slowing down? Shifting into 2nd gear? When you restart, is there a particular pattern or sound when it restarts? Is it hard or easy to restart? Does it start right up, or does the engine spin and "try to start" before it finally catches? And on and on. Try to isolate specific common issues and post those, please.
Try this first, and lets see what happens. Turn key to on, but not start, then off. do that about four or five times, then try to start. See if it starts, runs, then dies. Let me know. Have you had fuel pressure tested at all? If it doesn't start and run for a short while at least, take air intake hose off at throttle body intake, open throttle and spray a good shot of WD-40 into throttle body, then try to start. If it starts, you have a fuel delivery problem, maybe fuel pump or plugged filter would be first to check. Just because you hear the pump, doesn't necessarily mean it's getting proper pressure to run. Let me know what happens when you try this, and we'll go from there.
You need to replace your coil pack. It sounds to be over heating which results in no spark being sent and the enige dies. Very common fault and easily fixed.
