Question about Siemens Washing Machines
Display on my siemens extraklasse is saying pump blocked?
3 Suggested Answers
  • 274 Answers
SOURCE: can a siemens extraklasse xls 140 run as a cold
yes any machine can
Posted on Jul 05, 2010
  • 6277 Answers
SOURCE: my siemens extraklasse t900 washing
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 21, 2011
Stops working part way through programme
It seems it is drain problem and check out your drain hose and drain pump for problems and clean all main motor and pump as much as you could do
Dec 09, 2013 | Siemens 24 in. SE25A266 ExtraKlasse...
My Siemens extraklasse xls140 isnt always doing the final spin and the water doesn't appear to be getting hot during the wash.
I have a siemens ekstraklasse xls 140 and at the stadge it must spin and drain it says drain is blocked. Is there any way i can unblock it myself and where do i find it.
Jan 27, 2011 | Washing Machines
Pump taking water away but is on when door open or closed and machine will not start a new programme
Hi.
Check for a contact on door lock switch. Also check connectors on timer control.
If the machine keeps working and pumping with door open, then the problem is either wiring, door lock micro switch, or electronic control.
The electronic control will be last part to be tested.
Dec 02, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
The pump on my SE25A266 dishwasher ExtraKlasse Edition runs continuously
I removed the top and left side panel. Freed the float which was prevented form returning to the low position by the remains of a mouse that had unfortunately got trapped. The float is located forward lower left side. Trust that this is of assistance. Ian C
Oct 22, 2009 | Siemens Dishwashers
Display reads "pump blocked"
TURN OFF MACHINE AND UNPLUG THEN DO THE FOLLOWING:
Open the pump filter cover:
23294f2.png Remove and uncap drainage hose to empty detergent and then replace the cap.
Unscrew the filter and clean it, inspect the filter cavity inside the machine for matter that might be blocking it. Check the waste hose that leads out of the machine to see if there is a restriction somewere.
Oct 15, 2009 | Siemens WM14S794GB Front Load Washer
Siemens Extraklasse dishwasher - Salt light on
You can buy from any supermarket & it goes in container on left hand side of the dishwasher base(large knurled lid unscrews)
Mar 08, 2009 | AT&T Siemens S46 GSM Cellular Phone
Washing Machines Logo
55 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
