Question about Agfa Photo sensor 830s Digital Camera
How to format only the digital camera 830s sensor
    Brigadier General:
  • 11,967 Answers
The sensor can't and doesn't need to be formatted.
Posted on Oct 01, 2010
I want a new cable usb for agfa 830s sensor the mine is broken where i can to by e new please congratulations
You can get one from a camera or computer shop. Take your camera with you so they can supply you one that fits your camera.
Dec 22, 2012 | Agfa Photo sensor 830s Digital Camera
I have a V1003. It is saying memory card is protected (reset switch on memory card).
move the switch on the memory card, then put it back into the camera, if its still locked, take the card out and look did the switch move to the other posititon? if it did, then something is touching the lever as you put it in the camera.
if it did not move but the card is still locked. try formatting the card with the format option in your camera, if that doesn't help then the sensor in the camera that detects if the lever is on the locked position or not is jammed and thinks the card is locked, to fix the problem the sensor needs to be fixed, you need to take the entire camera apart to get to it.
May 30, 2011 | Cameras
Hi i buy duracell rechargeable is it ok to use the batteries or i had use alkaline
hi
you can use both.
the camera use just two of double AA.
Thanks and best regard!
May 23, 2011 | Agfa Photo sensor 830s Digital Camera
I have bought a F401 sold as brand new !!! once charged up instead of getting an image on the lcd screen all i get is coloured streaks - not good for a new camera eh ? i wonder if the sensor is faulty...
The newest review I could find on this camera was in 2007. I hope you received a manual with it. This camera uses an XD card an SD card will drop in the slot but not work. Okay when you first get the camera the day date and time need to be set. there is an internal battery that retains these settings. What you need to do is go into your menu and format your camera may call it initialize the memory card both the camera internal memory and the memory card in this case an XD card. It doesn't matter that it's a new card or camera the memory has to be formatted. each time you down load pictures to your computer hard drive the memory card will need to be formatted. After you have formatted your problem should go away, if not I'd be taking it back.
Dec 30, 2010 | Fuji FinePix Z5fd Digital Camera
What is the difference between DX and FX formats
The FX format uses a sensor very close in size to a frame of traditional 35mm film, about 36mm by 24mm. The DX format uses a smaller sensor, about 24mm by 18mm. The smaller sensor allows the camera to be smaller (compact point&shoot cameras use sensors much smaller) and also are less expensive.
The most visible effect of the difference is the so-called lens multiplier. The smaller sensor uses only the central portion of the image projected by the lens, in effect multiplying the focal length of the lens. In this case, a 100mm lens attached to a DX camera will give just about the same picture you would get with a 150mm lens attached to a FX camera.
In general, FX lenses will work fine on DX cameras, taking into account the lens multiplier mentioned above. DX lenses will not work properly on FX cameras, since the smaller DX lens won't always capture the full images needed to cover the larger FX sensor. Some FX cameras automatically switch to DX mode when it detects a DX lens.
Oct 18, 2010 | Nikon D90 Digital Camera with 18-105mm...
When I turn the camera on, the lense expands and then retracts. The viewer then displays "system error"
there is no image formation,u cannot see image on ur lcd/veiew-finder,allienment of the lens unit is defective/sensors of the lens unit problem,so take to a camera tec.
Mar 16, 2010 | Panasonic Lumix DMC-LC33 Digital Camera
Protected Photos
Hi there.
Check the card an make sure the write protect is not on, if it is,
face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Please post back if you need any additional advice.
Good luck and thanks for choosing FixYa!!
May 29, 2009 | Agfa Photo sensor 830s Digital Camera
Agfa Photo sensor 830s Digital Camera Logo
Top Agfa Cameras Experts
Larry Stiles
Larry Stiles
Tony
Are you an Agfa Camera Expert? Answer questions, earn points and help others
