Question about Sony KP-51HW40 51" Rear Projection Television
Is this fixable??
Picture fades out, seems really bright then goes all blue..sound stays on,
    Novelist:
    Champion:
  • 203 Answers
Unfortunately, this sounds familiar. Many of these sony projections had bad crt's.(picture tubes). Now here is a secret I learned along the way. The short in the picture tubes is in the filament, causing that color to overpower all others and sometimes causing pix to disappear until set is shut off and back on. If you are very careful and use an insulated screwdriver, you can sometimes tap on neck of picture tube and knock debris from filament causing extended tube life. This is dangerous and must be performed with set turned on. From front of set gently tap on neck of tube(s) in question using insulated handle of screwdriver to make contact with picture tube neck. Picture will probably flash whichever color tube is contacted. Eventually, if picture stops flashing that color as much, you can sometimes get several more months out of your set without any problems. Only alternative is to try a crt rejuvinator or replace tubes at a cost of 200.00 each if avail. plus labor. Good luck, Russmann.
Posted on May 28, 2008
My Nikon Coolpix S01 takes a very faded picture, which also shows on the screen. What caused this, and is it fixable?
All I can think of is either white balance, or exposure compensation. Have either of these deviated from the norm ?
Oct 06, 2016 | Nikon Inc Nikon Coolpix S01 Silver
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
Fadeing of picture RCA P52937
Sounds like it could be your bulb going bad I would check some places like rivervalleyelectronics.net or hdtvpartstore.com and see if they have your bulb is in stock it may not be to cheap but i beats buying a TV. I would direct you to the manufacturer but they probably have stopped supporting this type of tv.
May 13, 2013 | RCA P52937 52" Rear Projection Television
My ln-t4042h turns on and stays on for a while and then the screen goes blank then coming back on and off then stays blank. Also while it is actually working you can see the brightness fading in and out.
U have sound,after picture fated?Ur LCD inverter board it dead.must replaced this board to get the picture back.It usally a long board.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 06, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Panosonic 50" LCD 1080i HDTV screen picture faded
try setting your menu;s to adjust the picture settings
Aug 23, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
3,459 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
