Question about Cameras
Cannon ixy200f lens error how can i solve it.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 01, 2010
How solves System error e225 in cannon mf 4200 series ufrii lt
If you wish to get some details; check the site linked here. Pull up older posts..
http://electro-medical.blogspot.com/
Jun 28, 2016 | Canon Office Equipment & Supplies
Cannon digital camera error 32
This error comes when your Canon camera lens gets stuck in the barrel itself. There are some steps which can be followed to resolve this problem which as follows,
STEP 1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
STEP 2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
STEP 3: Just push and pull the lens slightly as it extends automatically.
STEP 4: Now when the lens is in the hard surface power on your camera.
STEP 5: Try to hit the camera softly beside the lens which might solve the issue.
You can try to format the memory card completely and then reinsert to your camera which might be the issue at times.
Feb 04, 2013 | Cannon Cameras
Cannon camera error 32
Error E32
Hi, I have cannon powershot 590. My camera is in the lens extended position and are not moving into the camera, There is a message on the LCD screeen "lens Error". Please guide me to solve the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 20, 2011 | Canon PowerShot A590 IS Digital Camera
'"The lens of my cannon
This is basically the infamous Canon "E18" error, which has been around for quite a while.
I would type out my own suggestions but since it's such a common error I'll just direct you to a nice long list of solutions already compiled elsewhere: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
I have Canon IXY200F.when i buy this camera packed with manual.The manual is in Japanese language so i can't read.so I want 2 user manual in english language.Can u please give me the link where i can...
In the US the camera is known as the SD1300. You can download the SD1300 manual from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd1300_is#BrochuresAndManuals
Aug 10, 2010 | Cannon Cameras
Cannon powershot SD1100 IS it displays the
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Nov 24, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Cannon sx100: displays lens error, restart camera
If your lens received impact damage it will need to be replaced. This is about a $150 bill at Canon. One thing that can happen is the flex cables that attach the lens to the camera system board may have come loose. You will have to have the camera opened by a qualified tech to see if this may be a solution.
Jul 02, 2009 | Cameras
The lens on my Cannon SD sure shot wil not close
Lens errors are fairly common for all digital cameras. Usually it's sand (be careful at the beach) or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
