Question about Acer TravelMate 2303LCi Notebook
I have Acer TM 4150. I has booting problem like when i put on my laptop it gives message to boot from 1- floppy drive 2-HDD 3- Cd Rom also in Cmos it shows no Hard disk or O HDD i restart it again then it shows HDD and then i select this HDD and it start booting till i shutdown the same problem occurs again.
    Master:
  • 473 Answers
Isssue with your Hard Disk... Possibility Data lost, due to power lost, or Bios Battery need to be change... To do So, Press and hold del button while you turn on your Laptop this wil bring you inside you Bios then Check carefuly set date and Time also set autodetect hard drive and set cd-rom first hard disk 0. second then the rest off... press F10 to save your change then restart your laptop then see if it will boot from itself.. if not ...Then put your XP CD on the cd-rom then re-start then press F-12 then chose Cd start to re-install your windows make sure you have your Cd key first then from anoter computer go on the net and download all your drivers for your laptot type down the model off your Laptop then on any browers type exemple; download ACER TM4150 drivers for xp or the one you use.. sample is that.. Good Luck
Posted on Oct 01, 2010
Starting up i get PXE-E61 media test failure some people tell me its the hard drive some say the cddrve others say it could be trying to boot from a LAN
PXe Boot is used by the computer to boot to a network DOS-type environment.If you are receiving a PXe failure message on bootup check that your PC is set to boot from the CD Rom, Floppy, and Hard Drive BEFORE network or other boot device.
That's where you need to check to get solution to your problem, if not... try these
1. your settings in your bios
2. faulty cable/wire to your media device (hard drive, cd/dvd rom, etc)
3. The cmos battery (which indirectly points to your bios settings)
Hope this helps!
Jul 18, 2011 | Toshiba Satellite L455D-S5976 Notebook
My acer aspire 5100 keepson giving me PXE-ROM error and I take the realtek card of the boot priority and put the first boot as cd-rom and 2nd as HDD. Then i put my vista disk in but it doe not start but...
If you've disabled the LAN option in the BIOS (or put it at the bottom of the boot order) then forget the CD and go back into BIOS and put the HDD as first in the boot order. If the laptop will not boot to the HDD then it is almost certainly the problem.
I got lucky once with this problem on an Acer by just telling the BIOS to go back to Default and the machine booted normally afterwards.
Aug 10, 2010 | Acer Computers & Internet
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
Can only get to BIOS, system will not boot to CD Rom. Unable to upload settings.
can u c the boot sequence in the BIOS....
if yes make to boot it from CDROM insted of Floppy/HDD
keep this boot seq. in BIOS
1 boot from CDROM
2 boot from Flopy
3 boot from HDD
Dec 17, 2009 | Acer Aspire 6930-6771 Laptop
Acer aspire 3515 reboot
Hopefully, though, there's just some craziness going on with the Boot
....suggests that the error messages you are seeing are from a failed
attempt to boot from a network source.
Check the boot order in your BIOS to insure that the hard drive is
fairly high in the list. Generally, I have it something like this:
(1) Floppy Drive
(2) CD-ROM
(3) Hard Drive
If you do this, will it boot from the hard drive?
Will it boot from a bootable CD?
Oct 02, 2008 | Computers & Internet
My Toshiba Satellite A135 is having a bad problem. it will not boot up. It says Media test failure check cable.. Does this mean my hard drive went out?
This message is primarily seen when the PC is attempting to boot from a network, and that network connection is no longer present. The error message would read PXE-E61: Media test failure / Check computer. Is this your message?
If it is, you need to go into the BIOS, and make sure that the sequence is 1) CD-ROM 2) HDD 3) FDD (if you have a floppy) 4) LAN (if you choose to leave the LAN there). Otherwise, switch option 1 and option 2. If the problem is the hard drive, however, putting the CD-ROM first will allow you to boot from your Windows CD.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
Jun 29, 2008 | Toshiba Computers & Internet
Acer Laptop crashed
first do one think remove the battery and start the system after getting on press f1or f2 or f12 or del button to enter into the bios screen after coming bios screen set the system to default settings and save and exit the system its restart check its working or not, still same problem remove harddisk and boot from cd -rom it will go for some installation , if it not goes motherboard if it goes harddisk problem
Mar 27, 2008 | Acer Aspire 9500 Notebook
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Acer TravelMate 2303LCi Notebook Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
