Question about Coffee Makers & Espresso Machines
Stalls during brewing My Gevalia Model CM500 12-cup coffee maker used to brew a pot in about 8 minutes. Lately, it repeatedly stalls during brewing. It just sits there doing nothing for 10 minutes at a time, then starts brewing again. This stalling makes the process of filling the carafe take up to 40 minutes. What is wrong?
    Master:
  • 473 Answers
Issue with Element... check thermoresistor ..possibility of crack on the Element,,,
Posted on Oct 01, 2010
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
I have a Gevalia Kaffe 12 Cup Automatic Coffee Maker (Stainless Steel) Model CM-500B (Black). Date Code: S1710. (Global Marketing Corp. warrants the coffee maker, thru Gevalia) It worked perfectly for...
Hello, point
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 19, 2011 | Gevalia CM-500 12 Cup Coffee Maker
Our office has a Gevalia Deluxe coffeemaker. It
Most likely the cycle thermostat that turns off the heating element has failed. It is supposed to reset after the it senses the water temp below 130 deg. If it did not reset or has failed it will not turn on the heating element but the clock will work fine.
By the time you ship the unit to a repair center with parts and labor and get it returned to you the cost would be as much as a new unit.
Thanks for using FixYa.
Kelly
May 13, 2010 | Gevalia CM-500 12 Cup Coffee Maker
Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Xcc-12 gevalia coffee pot wont brew.
Thermal link open. Located in base of unit mounted against the warming pad heating unit.
Oct 28, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Gevalia xcc-12
clean with limeout, or coffee maker cleaner, I used about 1/2 cup liquid limeout 2 cups water, run through bout 2 times, be sure to run several pots water through after cleaning,
Apr 25, 2009 | Gevalia 50041 / 50443 Coffee Maker
Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Feb 14, 2009 | Gevalia CM-500 12 Cup Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Coffee doesn't brew full pot
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
158 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
