Question about Maytag Refrigerators
How do I replace a refrigarator door gasket? - Maytag Refrigerators
    Brigadier General:
  • 3,513 Answers
Please check the bellow links related to your query:-
http://www.ehow.com/how_8259_replace-gasket-refrigerator.html
http://www.ehow.com/how_5026255_change-refrigerator-gasket.html
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 01, 2010
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
Mar 09, 2015 | Amana Refrigerators
Ice maker on refrigarator does work
Place ice trays outside your back door and wait. (Yay Canada!)
Oct 06, 2013 | Computers & Internet
How do I replace the oven door gasket on my VGIC3686
Replacing a Door Gasket
If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
Apr 16, 2012 | Viking Kitchen Ranges
Maytag side by side refrigarator Mod, RSW2400EAE refrigarator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 16, 2009 | Refrigerators
Motor keeps shutting off
It's a problem very common on this brand of refrigarators that the compresor relay goes bad and needs to be replaced(located on the side of the compresor under the black plastic cover).
Jul 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool refrigerator side by side.The problem that i am having is that the freezer side cool's but the refrigarator side does not cool at all.
Please check your door gaskets and in case it is in bad shape do change it immediately. Or even a block in the system could result in partial cooling.
Jul 06, 2009 | Refrigerators
Need help with fridge
how do you get to fan at in back of refridgerater
Dec 27, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
112 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
