Question about Microsoft Windows Server Standard 2003 for PC
Application error in 2003 server
Dear sir,
we found followling error
intouch-windows viewer:-view.exe-application error
the instruction at " 0x00544045" referenced memory at "0x21530010" the memory could not be read.
    Problem Solver:
  • 6 Answers
Check RAM
Posted on May 26, 2008
What does 'Unknown Server Error 500' mean?
This is caused by incorrect MIME handling by Windows when 'DBF Viewer 2000' is installed. The 'DBF Viewer 2000' program associates the .DBF file extension with 'application/DBF Viewer 2000' instead of 'application/octet-stream'. Remove 'DBF Viewer 2000' from the affected system. If you are still experiencing the issue I can suggest this program DBF Repair Toolbox https://www.repairtoolbox.com/dbfrepair.html
Mar 31, 2016 | Computers & Internet
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
May 11, 2011 | Epson POS TMT88IV Thermal Receipt Printer...
How we can remove active directory in windows 2003 safe mode ?
hello,
you just try to remove as force.
go to run, after this type " dcpromo /forceremoval ".
it will do this for you, if any issue on active directory or ad database.
you can do this command in normal or safe mode.
thanks,
Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Hpqselsk.exe clr error 8004005 & cant open hp director
Its also known as .net framework. Its a software which few applications use for support like chat applications. Below is the system requirement for .net framework to work properly If your system does not fall under the category then you shall uninstall it.
  • upported Operating Systems: Windows 2000; Windows Server 2003 Service Pack 1 for Itanium-based Systems; Windows Server 2003 x64 editions; Windows Server 2008 Datacenter; Windows Server 2008 Enterprise; Windows Server 2008 for Itanium-based Systems; Windows Server 2008 Standard; Windows Vista Business; Windows Vista Enterprise; Windows Vista Home Basic; Windows Vista Home Premium; Windows Vista Starter; Windows Vista Ultimate; Windows XP; Windows XP Professional x64 Edition
Jul 26, 2009 | Office Equipment & Supplies
Explorer.exe - application error
Try the following to gather additional information.
Run a test on the hard drive(s) for any bad sectors via chkdsk
Run a memtest to verify the integrity of the physical memory. I would suggest the memtest via the Knoppix CD.
Look in the Windows Event Viewer, Application and System log for any possible resource contention issues or other system problems.
Dec 13, 2008 | HP Compaq ProLiant ML530 Server
How to fix spoolsv.exe - Application Error on windows 2003 server
Click on the link , a very very easy solution to fix spoolsv.exe
http://www.instant-registry-fixes.org/how-to-fix-spoolsvexe-application-error/
Aug 22, 2008 | Microsoft Windows Server Standard 2003 for...
Win 2003 Server Reboot
Is it loading up to windows logo? if you are not getting blue screen error massage most of the time you can fix it on safe mode. try to get into safe mode and read all logs there you will see the problem.
Dec 06, 2007 | Microsoft Windows Server Standard 2003 for...
Terminal server not responding
Are you receiving errors in the "event viewer"? And if you are what are they?
Oct 20, 2007 | Computers & Internet
Microsoft Windows Server Standard 2003 for PC Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
