Question about ASUS P4P800-X Pentium Motherboard
I used 1gb ddr400 to my Asus P4P800-X, it works, but after a few days it always turn black my screen, sometimes i can used it more than an hour & sometimes 5 - 10mins long.. i used another 1gb ddr400.. but still the same error..in the BIOS , only Automatic, 266mhz & 333mhz are my options, is it possible that error is caused by my ddr400 memory? is ddr400 supported my mobo??.. and what is the purpose of black & Blue slot Dimm..
  • 52 Answers
The black and blue slots are to indicate where paired sets of identical DIMMs should be inserted. So one pair would use the blue slots and the other pair would use the black. It's possible that your motherboard doesn't fully support this RAM type but you would only be able to find that information at the Motherboard maker's website. Hopefully they still have BIOS updates for that motherboard posted online so you can update it. Sometimes all you need is an update to the BIOS to support newer processors or memory.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Posted on Jun 30, 2017
SOURCE: Asus P4S8X-X - Pentium 4 - 2.4 GHz
I would try another Power Supply Unit.. are you sure it's the PC and not the monitor thats faulty? You could check this by connecting another monitor,and see if it does the same...
Posted on Jul 30, 2007
s2dak_jr
  • 42 Answers
SOURCE: 3x 1GB DDR400 Problem on booting!
the details for your case can be obtained in this site.....................
http://www.memory4less.com/m4l_results.asp?ref=mem&modelid=800121
read carefully to understand the limitations that arise with your motherboard.
cheers....................
Posted on Jan 22, 2008
tom19511
  • 1601 Answers
SOURCE: Burnt DDR DIMM socket
you can probably use the other 3. But 1 wont run as DDR.
How did you get it burnt?
Posted on Jun 09, 2008
ohms
  • 1879 Answers
SOURCE: K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 19, 2008
SOURCE: asus p4p800-x no screen no beep
Could be that your ram is either Bad or the wrong type. I just had a similar problem. I changed the ram and up it came.
Posted on Aug 04, 2008
Man
If you are looking for the device drivers for your ASUS motherboard then -
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jun 09, 2011 | ASUS P4P800-MX : ATX Socket 478 FSB800...
How much ram and at what speed will i get best performance all around onn a P4P 800M mobo ? Is running a 2.4G asus processor and has 2 256 sticks running at 44g mhz. I would like to use 1 gig sticks but...
As far as i remember that motherboard has 4 DIMM (ram) slots supporting a maximum of 4GB DDR400/333/266 memory also it has Dual Channel Memory Architecture.
Regards.
Apr 21, 2011 | ASUS P4P800 Motherboard
I am using Intel D865GBF board having Dual Channel DDR400/333/255 SDRAM memory support. It is of 3GHZ, 256 MB RAM. The other day I bought 1GB RAM of Transcend and tried fitting the same. But the PC never...
Yes it can support 1GB ram. Max capacity up to 4GB of ram, meaning 1GB each on each slot. Make sure that the memory that you will be installing are either DDR400, DDR333 or DDR266. It could be the RAM is faulty if the one you bought is the DDR's that I mentioned
Oct 11, 2010 | Intel D865GBF Motherboard
I have p4p800 se 2.6 ht cpu I recently bought 2-1gig sticks of ddr400 pc3200 cl3 hp memory and tried everything I could think of wont boot can anyone help
Asus gives this as the board memory spec:
-4 x 184-pin DIMM Sockets support max. 4GB DDR400/333/266 non-ECC DDR SDRAM memory
I suspect you bought DDR2 type memory.
Apr 16, 2010 | ASUS P4P800 SE (890552603657) Motherboard
PCI Simple Communications Controller, seem not to function
Hello my friend
First your motherboard does not support windows 7 and the maximum ram capacity is 4GB DDR400/333/266 non-ECC DDR SDRAM memory
Second you can go here and check which memory your motherboard supports
P4P800 SE Memory QV
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/P4P800_SE_QVL.pdf
Third you can try updating your Bios,more information in your manual
MANUAL
http://dlsvr.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
your motherboard details is here
http://www.asus.com/product.aspx?P_ID=YNlDkmz5gSNpiCr6&templete=2
Good luck
Jan 14, 2010 | ASUS P4P800 SE (890552603657) Motherboard
I need to find out how much RAM my computer will handle but I do not have a users manual. I have a P4P800-MX motherboard. How can I find this out?
Your computer motherboard supports maximum 4 GB DDR400/333/266 non-ECC DDR SDRAM memory.
For more details and specifications, click here
Hope this answers your query. Thanks for using FixYa.
Dec 17, 2009 | ASUS P4P800-MX Motherboard
In my Asus P5S800-VM motherboard, it won't accept 2 ports of RAM
Check the RAM in another machine if it worked then the RAM slot might have some problem....
Mar 30, 2009 | ASUS P5S800-VM Motherboard
Asus p4p800-x no screen no beep
Aug 04, 2008 | ASUS P4P800-X Pentium Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
ASUS P4P800-X Pentium Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
