Question about Maytag CWE5800A Electric Double Oven
Broiler not working - Maytag CWE5800A Electric Double Oven
Replaced electric control broiler doesn 't work
Posted on Nov 17, 2010
My broil HAS NEVER WORKED. top element does not heat up even after the control panel was changed.
Search Results
    Gas Oven Broilers - Do Any Really Work? - Chowhound
    www.chowhound.com/post/gas-oven-broilers-work-923543
    Nov 8, 2013 - but do want to say that I broil in my Breville Smart Oven and it's great.... I have never had a gas stove in any home I've ever lived in, always ...
    Kitchen Basics: How To Use Your Broiler ' The Kitchn
    www.thekitchn.com/kitchen-basics-how...
    Apartment Therapy's The KitchnMar 31, 2010 - Every oven that we've ever come across has some kind of broiler - it's the same device as heats your oven for baking or roasting, after all.
    I have a Kenmore electric range; model 920/9285*. The ...
    www.shopyourway.com > Manage My Life > Questions
    The oven and broiler on my stove won't heat up. Was working ... Having a Oven not working can be rather disappointing as well quite a concern. I have taken the ...
    Top or Bottom Broiler? [Archive] - CookingLight.com Community
    community.cookinglight.com > ... > Food > Popular Threads Archive
    Sep 3, 2002 - 24 posts - ‎7 authors
Jan 27, 2016 | Stoves Ovens
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Top Broiler works, oven does not work at all
hi yes you could replace the broil for the bake but they are very fraglle so i would buy a new bake igniter replace
May 18, 2008 | GE JGRP17 Gas Single Oven
Broiler element not working
It's either the switch that supplys power to the broiler element or it's the element itself (probably the element itself). I'd go after that first as it's not that expensive.
It's not a thermostat because if it was, the bake element wouldn't work either. The broiler element is not supposed to come on except when in the broil mode or cleaning mode.
Mar 13, 2008 | Amana AOES3030 Electric Single Oven
Maytag CWE5800A Electric Double Oven Logo
107 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
