Question about AOpen Titanium GT Computer Speakers
How are the speakers connected on the back - AOpen Titanium GT Computer Speakers
10 years and first problem to repair. When you turn on and select DVD or any other selection a very loud cracking noise comes through right speaker only. So loud (with volume tuned off too) that I fear...
I think your receiver is damaged.
Try this.
Mark the speaker wires on the back of the receiver. label the speaker connected to the left channel "Left" and the speaker connected the the right channel "Right"
Also pay attention to the polarity (positive an negative) making some type of marking on your speaker wire so you can reconnect them correctly.
Disconnect both left and right speakers.
Connect the speaker wire that is labeled "Right" to the receiver's left speaker connections only then turn your receiver on.
IF the loud noise comes back, this speaker is damaged. I am guessing that the speaker is fine.
Now connect the speaker that was labeled "Left" to the receiver's right speaker connections and turn the receiver on.
IF the loud noise comes back like it did before but now playing through the "good" speaker there is a problem with your receiver.
If so, your receiver is 10 years old. Isn't it time for an upgrade? Try ebay for good used equipment deals.
May 01, 2014 | Onkyo TX-DS787 Receiver
How do I get a diagram of how to connect my speakers to the back of my Windows XP computer?
The only cable you will connect to pc is the green plug one that go from the speakers main box to the back of the pc.
Oct 27, 2011 | Altec Lansing 151i 5 Speakers
Just want to know how to hook up speakers
On the back of the Technics Receiver you should see black and red speaker connections where red is positive and black is negative. One the back of the speakers you should see similar places to connect the wire, with speaker wire stripped at each end, you should attach one end to the speaker and the other to the back of the speaker corresponding with the black and red (negative and positive) connections.
Hopes this helps, feel free to ask me any more questions
Jun 18, 2011 | Technics Audio Players & Recorders
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
One of my speakers got disconnected and I don't know where to plug it in.
Typically, the LEFT speaker connects only to the RIGHT speaker.
The RIGHT speaker connects to the LEFT speaker.
The RIGHT speaker connects to the AC power-supply.
The RIGHT speaker connects to the "green" port (not the nearby "blue" nor "pink" connectors) on the "back" of your computer.
Check the connections.
Oct 29, 2009 | Dell Audio Players & Recorders
Don't know how to hook them up
What a lovely daughter, how very nice of her,
here goes....straight for Mr. Koss
To Operate with AC Adapter
  1. Open battery compartment located at the back of both speakers and remove wires.
  2. Replace battery covers.
  3. Connect DUAL PLUG CONNECTOR on left speaker to right speaker at connection marked "TO LEFT SPEAKER."
  4. Connect remaining wire with 3.5mm plug to headphone jack on your audio source.
  5. Connect AC adapter (not included) to back of left speaker at connector marked "DC 6V." Plug remaining end of AC adapter into wall outlet. Be sure your AC adapter is built with the center pin as ("-") negative. Connect remaining wire with 3.5mm plug to the headphone jack on your audio source.
  6. Turn ON/OFF switch at back of right speaker to "ON."
  7. Set "INPUT SELECTOR" switch to audio source.
  8. Turn on audio source
  9. Adjust sound in the following ways: Turn volume control to desired level; push Bass Boost button located on right speaker to "ON" for added bass; push Treble Boost button on right speaker to "ON" for added treble
  10. Operating a microphone through your speakers require an additional 3.5mm plug to 3.5mm plug cable (included). Connect cable with 3.5mm straight plug to right speaker at input marked "MIC" on back of speaker. Plug the remaining 3.5mm L--plug into the mic input on audio source. Connect your microphone to the front of your speakers at "MIC" input (microphone not included)
Hope you have all of the skinny you need, good luck,
please leave a rating, thank you kindly
Apr 27, 2009 | Computers & Internet
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Speakers
If I understand you right, you have 7 speakers on 7 different channels.
When you have just 1 speaker connected it sounds fine, but any time you add more speakers it shuts down, or does it sound fine until you have all 7 of the speakers connected.
Bare with me, and we will figure this out. It is a very diificult job trying to troubleshoot something that is not in front of you.
After this post, it will be about an hour or so before you will hear from me again, I will be on my way home from work.
Is this a 5.1 surround system or is it listed as 7.1?
Do have have any speaker outputs with more than 1 speaker connected to it.
If this is a 5.1 system, do you have speakers connected to the "A and "B" speaker jacks?
What kind of speakers are they, and do they say on the back where you connect the speaker wire what ohm rating they are. Most speakers for your home are 8 ohms.
in case you were wondering what a 5.1 and a 7.1 system is:
the 5.1 system has front right, front left, center, rear right, rear left and the .1 is for the sub-woofer that is normally a RCA jack output on the back of the receiver
The 7.1 has all those same speaker outputs plus it has a surround back with right and left channel.
I will get back to you in about an hour or so.
Jun 23, 2008 | Audio Players & Recorders
AOpen Titanium GT Computer Speakers Logo
23 people viewed this question
Top AOpen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AOpen Audio Player and Recorder Expert? Answer questions, earn points and help others
