Question about Lutron White Magnetic LowVoltage Dimmer Switch DVLV600PHWH
I have 2 lucent light switches that broke I need the toggle switch front unit
  • 56 Answers
You will have to replace the entire switch. If they are not to old sometimes they will exchange them out for a new one
Posted on Oct 01, 2010
Need a replacement on-off switch for a DeVilbiss GB5000-2 generator
My switch broke as well. Instead of trying to find one, I removed it, and mounted a heavy duty toggle switch on the front of the shroud, just below the original location. Connect the original wire to one side of the switch, and a wire connected to a good ground to the other side. Btw, the off position on the toggle switch is run, and the on is now off. This repair has served me for years.
Jul 20, 2012 | Briggs & Stratton Briggs and Stratton...
Turn switch is broke and rigged to work and my dash lights as well as tail lights dont work when headlights are on. trying to find which wire is the dash/tail lights
buy a new switch or used switch for the vehical other wise hook up a toggle switch to a power for headlights and use the switch for other lights if you wanna keep it rigged but i would just replace the switch hope this helps you =check fuses=
Jun 27, 2011 | Mitsubishi Mirage Cars & Trucks
Yes im tring to find the parking wire i dont know what color it is trying to watch video not working
The parking brake wire for this unit is light green. Try connecting it the unit's ground wire (black) and test for video. If it does not show video when connected to ground, install a two wire toggle switch. Connect one wire of the toggle switch to the light green wire and and the other wire of the toggle switch to ground. In this manner you will be able switch the screen on and off when viewing videos.
Nov 23, 2010 | Kenwood DDX514 Car DVD Player
Where is the wireless switch on this dam thing
Some laptops don't have a mechanical switch for wifi. But just try to look around the back portion or the front or sides of your laptop. Wifi switches are slide type. You just slide it to toggle on and off.
However, newer laptops have no mechanical switches. To turn your wifi on/off, just hold down the FN key and press the Function Key (F1 to F12) where you can see the wifi logo like this: )))
In my unit, it is FN+F10
Try it out.
May 22, 2010 | Acer Aspire One PC Notebook
A420n broke the button to turn it on needs replaced
When mine broke all i did was disconnect the two wires from the button, solder to a small toggle switch,drill a hole in the case and fit toggle switch,works fine
Feb 07, 2010 | HP Pavilion a420n PC Desktop
How do you turn off freezer,refrig. is a side by side with a lower freezer that pulls out. Recently moved and freezer door broke and need to use just the refrig.
I don't believe you can turn off the frezzer section because most if not all frezzer/fridge units use the frezzer section to cool the fridge side!!!! that's just how they are designed.
Sep 21, 2009 | Refrigerators
Broken Toggle switch
A toggle switch is a common item. Remove the broken one and take it to a hardware store where they will match it up so u will have the new one u need.
Apr 29, 2009 | FrancisFrancis! X1 - Stainless Steel...
I can not watch the videos and movies in my Kenwood KVT 617 DVD
hi there
on the back of this unit is a green brake wire you need to buy a 3 pined toggle switch ...........you need to take a small but mid size length speaker wire and attach to 12v (red wire) going into back of kenwood unit add another speaker wire to the ground wire (black wire) of kenwood unit... now on the 3 pined toggle switch add the power speaker wire to the toggle switch add the ground speaker wire to the toggle switch once this is done add the green wire to the last toggle switch pin........put the kenwood unit back in dash.......now turn the car and toggle switch on...........put in a DVD and if screen shows DVD all is done...... but if the screen does not show the DVD......just switch the green wire with the black wire on the toggle switch and now it should work
hope this helps
Mar 02, 2009 | Kenwood KVT-617DVD Car DVD Player
I need to know how to wire my deck.
buy a toggle switch
run a wire from the red wire located at the back of deck
to the deck and toggle switch (power to power on toggle switch)
do the same with the ground wire (black) (ground to ground on toggle switch) (make sure to follow logos on toggle switch)
finally install e brake wire to center pin on toggle switch
now you can watch make sure toggle switch is on
if this didn't work switch the e brake wire and black wire on toggle switch
good luck hope i helped
Dec 08, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Lutron White Magnetic LowVoltage Dimmer Switch DVLV600PHWH Logo
55 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
