Question about Husqvarna Forest & Garden 125bt Backpack Blower
Starts easily, but won't rev for 10 mintues. After warm, max speed is low / lacks power. New plug & gas filter
    Scholar:
  • 150 Answers
Check to see if the muffler is blocked.There is a screen (spark arrester) at muffler exhaust these get blocked. Usually 1 screw holding it in. Remove screen and replace or clean. I use bernzomatic torch to burn out these deposits.
Posted on Oct 01, 2010
No power at high rpm
Could be a problem with the main jet,carb slider or a diaphragm fault
Aug 07, 2012 | Motorcycles
Hi have a issue with a mazda .ford product
need to check timeing and valvs might have jumped time or bent a valve or two when it reved up
Dec 08, 2011 | 2007 Mazda B2300
Why wont my chevy tahoe pick up speed ? we did everything , new spark plugs , new gas filter ,new fuel pump , new air filter , new gas filter , new spark plug wires , still it wont pick up speed . Why ?
did you check the timing? the firing order.
does the engine rpm rev up high? if it does then check the transmsission for low on fluid or slipping.
check your catalytic converter for clogged up.
Apr 27, 2010 | 1997 Chevrolet Tahoe
My Homelite CSP3314 chainsaw starts perfectly, and warms up. I am unable to rev the saw to full power as it cuts out. I have changed the old petrol & 2stroke with fresh but problem continues.
First thing you do is remove the air cleaner and do a test run to see if you reach max speed.
If you reach max speed... change the air cleaner.
If symptom is the same without the air cleaner there are either on or 2 screws on the carb.
If you only have one screw turn the screw about 1/8th turn CCW and try it again. Keep adjusting until you get max speed.
If you have 2 screws marked H & L then make the CCW adjustment 1/8th turn and retest speed. Adjust until max speed is reached.
NOTE: If speed actually decreases after making the adjustment. Reverse direction and turn it CW.
If all ajustments make no difference then the diaphram / float in the carb will need to be checked. the diaphram for holes and the float for proper operation / debris.
Lastly.... if there is an inline fuel filter check that also.
Reinstall air cleaner.
Thanks for using FixYa.
Kelly
Mar 10, 2010 | Air Tools & Compressors
Despite new spark plug properly gapped, cleaned & lightly oiled filter, fresh gas, and CHOKE IN PROPER POSITION, my trimmer (purchased 10/9/2004) still hesitates and then stalls. Cannot rev it up. Is...
Check your spark, as you may need to respace the magnetron on this if it isn't sparking continually. Just loosen the two bolts holding it on, place a notecard (3 x 5) in between it and the flywheel and then tighten it down and against the notecard. This likes to loosen up on small engines and is overlooked easily. Let me know how this turns out.
Benjamin
Jul 24, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Diesel rodeo dies and lack power when cold and in winter
Try changing the fuel filter and get the glow plugs checked or replaced .Diesel goes a little waxey in colder weather making it harder to go through the filter .
Hope this helps.
Jul 23, 2009 | 1988 Isuzu Trooper 2 Door
Starts O.K. Lacks pulling power. Will not rev to full power.
check for a clogged exhaust look at catalytic converter it could be stop up.
May 24, 2009 | 1999 Suzuki Vitara
Truck lacks power
Check the fuel filter (could be plugged) or it might possibly need a new catalytic converter.
Oct 26, 2008 | 1999 Chevrolet S-10 Pickup
Husqvarna Forest & Garden 125bt Backpack Blower Logo
440 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
