Have "The Hammacher Schlemmer Projection Alarm Clock and Weather Monitor" Unable to change change time zone from PST to EST in spite of following directions on page 15 of the user's manual multiple times. Please advise. L J Fetters
  • ljfetters Oct 01, 2010
    Thanks!
    Was able to reset from PST to EST. The essential point was to have the clock in "day of the week" mode.
    Surprised this key bit of information wasn't in the user's manual.
    President:
  • 2,185 Answers
Please confirm if this is how you change the timezone.
1. Locate the "Mode" button on the front of your Hammacher Schlemmer projection clock.
2. Press the "Mode" button, and wait for the clock to show the day of the week in place of the seconds on the clock's display.
3. Locate the "+" button on the front of your Hammacher Schlemmer projection clock.
4. Press the "+" button to access the time zone-setting screen. Note that icons for the Pacific, Mountain, Central, and Eastern time zones will appear on the screen.
5. Press the "+" button repeatedly to highlight the desired time zone icon on the display screen of your Hammacher Schlemmer projection clock.
6. Press the clock's "Mode" button to return your projection clock to its regular timekeeping mode.
Also, try to see if you have a button to reset back everything to defaults then try again.
Posted on Oct 01, 2010
    President:
  • 2,777 Answers
Does it change to other time zones just fine and not EST?
Let me know and I can help
Thanks
Tim
The projection piece only projects portions of the digits. What can I do to fix it so that all of the digits project appropriately?
I suppose you'd have have to mess around with the lens. If you go to hammacher. com, they can help you. This radio has a lifetime warranty, so it's said
Jul 06, 2014 | Hammacher Schlemmer The Projection Alarm...
Change time zones
Hold down the + button on front of unit until the time zone moves.Then let go when it reaches the correct time zone.
Jan 26, 2014 | Hammacher Schlemmer The R2-D2 Projection...
My Hammacher Schlemmer Projection Alarm Clock and Weather Monitor will not project the outside temp. It only projects the inside temp. How do I change? Also, can't change the time zone.
No solution but to return it...very annoying product but yet I like the projected display, very sharp and bright. The replacement was much better, it loses connection with outside transmitter often..but occasionally we see the outside temp
Dec 28, 2013 | Hammacher Schlemmer The Projection Alarm...
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    Skyscan atomic wall clock 87315. Changed battery
    Press and hold the set key until time zone appears, then + or - to your zone.
    Jan 31, 2010 | SkyScan Audio Players & Recorders
    Peaceful Progression Wake Up Clock manual Hammacher Schlemmer
    go to the Hammacher Schlemmer web site (www.hammacher.com) and in the search box insert "peaceful progression wake up clock".
    Just below the description of the clock there is a heading "instruction manual", click on this and download the instructions.
    Jan 23, 2010 | Watches
    I have a battery operated satelite clock that deplays the time, day, temperature, alarm, and world time. I lost the instructions on how to operate. Please help0!
    Successful reception of the time-synchronization radio2_bing.gif signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
    Jan 19, 2010 | La Crosse Radio Controlled Atomic Clock
    Digital atomic clock radio
    Hi. There should be a switch on top of the radio that allows you to select the time zone. It is just behind the snooze bar and labeled PST-MST-CST-EST. Try that.
    Mar 31, 2008 | SkyScan 34202 Clock Radio
    Can't set time zone
    Try pressing and holding the -CF for three seconds then press it again. The P (Pacific Time) appears, press it again and the M (Mountain time) appears, etc.
    Nov 21, 2007 | Watches
    1,482 people viewed this question
    k24674
    jasbo
    jasbo
