Question about Dell A215 Computer Speakers
Control Panel says I have no audio device. Speakers are plugged in and have power.
    Problem Solver:
  • 7 Answers
The problem is not with your speakers, it is in your sound card or device drivers. In control panel, double click on system. Then single click on hardware/device manager , down the list click on the + next to sound,video and game controllers. If you have an aftermarket sound card, look for it in the list. Right click on the device, and then "update driver".
Posted on Oct 01, 2010
  • Jim Ludwig
    Jim Ludwig Oct 02, 2010
    Additional possibility ? Are you plugged into the (line out) jack? Heiroglyphics behind your computer, hiding beneath all your cables and such, can be confusing in a low light situation. ((
  • 4,889 Answers
No audio device implies that you do not have a driver installed for your soundcard/on-board sound. To verify this click start->Run and type in devmgmt.msc and hit enter. When the device manager opens click the + sign next to sound video and game controllers and see if there are yellow exclamatory marks next to any of the devices . Post back with what you found so that I can verify if its indeed a driver problem and then get you the driver.
Sai.
Altec lansing GT 5051 will not power up
there can be a number of things than can cause this problem
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 27, 2011 | Audio Players & Recorders
Speakers are plugged in and power can be heard through them but no audio sound is coming through. I have just had a system repair on my PC (in case this helps in answering)?
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 22, 2011 | Kinyo PA-390 Computer Speakers
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
Jul 01, 2011 | Logitech X-530 Computer Speakers
I plugged in the Logitech Z4 speaker system, all the connections are on correctly but there is no power going to the speakers. Tried two different outlets, still no power. The power button is on. ...
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
Jun 27, 2011 | Logitech Z4 Speakers
My speaker are not working. everything ishooked up, it says on my vloume control that there is sound but i hear nothing
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Mar 15, 2011 | Cyber Acoustics CA-3090 Computer Speakers
My speakers just dont seem to even turn on any more all is plugged in but it seems to have no power no light goes on or anything. power outlets have power i test them with my tv dont really know what...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 24, 2010 | Logitech LS-21 2.1 Speakers
My speakers (insignia) are not putting out sound and windows is telling me they have no audio device. but, my speakers are plugged in and have power.
hope this helps
Oct 01, 2010 | Insignia 2.1 Speaker System (3-Piece)
I just re-assemble my computer and speakers and my speakers is not working now. I am not sure if I have left a plug out. Should something be plugged into the 'Audio In" slot?
Audio in is an auxillary imput. Your speakers should be plugged into audio out. Check the power supply to your speakers. Enter Control Panel > System> and Device manager and make sure your audio drivers are working. Also enter Control Panel > Sound and Audio Devices and check the box that says "Place volume icon in the taskbar then open the volume control and make sure none of them are muted and that your volume levels are high. You can then click on the sounds tab and choose one of the sounds and hit the test button to check your speakers. Hope this helps. If all else fails check your speakers on someone else's computer.
Nov 19, 2009 | Philips MMS171 Computer Speakers
My speakers won't work we tried everything
do you have the audio drivers installed on your computer.go to control panel,sound,speech and audio devices and then click on sounds and audio devices.it should open up another window sound and audio devices properties.click on audio and check default audio device.should have some devices e.g realtekAC97.if its not there, google it to install and it should work.if this doesnt work please let me knoa.
May 30, 2009 | E-Machines eMachines T3830 PC Desktop
Speakrs don't work on new HP Pavilion desktop.
If you're using Windows XP, go to the Control Panel, then double-click on Sound, then go to the Audio tab and make sure the playback device is set to your Realtek output.
If you're using Windows Vista, go to Control Panel and click on Hardware and Sound, then click on Sound. Make sure your Realtek device is selected with a green check mark. If it isn't, just click on it and then click the Set as Default button down below. Vista sound configuration is kinda quirky, and it does do some kind of detection when you plug a cable into an audio jack, so you might leave this screen up while you plug your speakers into the green audio jack in the sound card and see if it pops anything weird up.
Apr 17, 2009 | Computers & Internet
Dell A215 Computer Speakers Logo
103 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
Rick Davis
Rick Davis
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
