Question about Frigidaire Dryers
Dryer sounds like a pair of sneakers inside when running
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 01, 2010
Ran dryer towels and sneakers didn't dry compleatly took out sneakers ran gave code AR drum turn and heats?
Make sure that the exhaust vent is not clogged! If it is, the unit will not dry anything properly since the humidity has no way of leaving the inside of the machine.
Apr 10, 2015 | Maytag Whirlpool Cabrio High Efficiency...
Black huge dust particles after clothes or done washing
The dryer uses a rubber belt and only lasts about 5 years +/- 1yr. So, when it wears down in the groove. Groovy eh?: No, seriously, the belt wears and if not replaced in time it will start to wear unevenly. This causes a black dust or chunks of rubber belt to accumulate and spread inside the dryer and gets on your cloths. Remove the back cover and inspect the belt. If it looks like it's wearing real bado replace it. If not look elsewhere like the motor etc ... Also make sure jr. Isn't throwing his sneakers in there. That can run your dyer. Sneakers should be packed full of old newspapera and set out fir a day to dry. NOT THE DRYER.
Feb 16, 2015 | Washing Machines
How to assemble belt
Hello Denise, I have seen this problem many times. The sneakers by themselves in the dryer cause a shock effect , when the weight of the sneakers tumbling onto the drum overloads the skinny belt and the belt breaks every time. Usually. if you dry the sneakers along with other clothes or towels this will not happen.
Feb 27, 2014 | Estate TEDS840JQ Electric Dryer
I have a Kenmore 110.63032102 dryer and I put a pair of sneakers in it. It shut off and now it wont even turn on. What's wrong?
Drying a pair of sneakers causes the dryer to overheat and this causes the thermal fuse to blow. The thermal fuse is wired in series with the motor circuit and if it blows, power to the motor is terminated causing the dryer not to turn on. Disconnect power then Pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to expose the thermal fuse on the blower housing.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Let us know if you need further advice.
Jan 26, 2011 | Kenmore Dryers
Professional help, on best volleyball shoes?Does anyone who play volleyball know what would be the best volleyball shoes. I really want new shoes that will be comfortable and not hurt my feet.
I've owned Mizunos and Adidas sneakers, each with the name brand's intended volleyball sneaker. I do not know which models specifically I used. Each pair of these volleyball specific shoes retails for close to $100. My other sneakers I have purchased for volleyball were an array of cross training sneakers. Nike, Reebok, and Adidas.In my experience, the volleyball specific sneakers were less comfortable than a pair of cheap cross-training sneakers.My recommendation is that you go to your local Sears / JCPenney / Foot Locker, or Sports Authority, and check out any cross-training sneaker on sale or clearance.
Oct 27, 2010 | Clothing Accessories
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Dryer sounds like there is a sneaker bouncing around inside it starts out really loud and then quiets down and then starts up load again
open the case the drum has come loose and you just need ta replace the front seal most likely
Aug 04, 2009 | Dryers
Maytag Gas Dryer LSG7800AAW makes noise at start up
heatman101
789f
Aug 03, 2009 | Maytag LSE7806A Top Load Stacked...
15 year old Kenmore dryer not working
Sounds like you thru the breaker. If not, it is the door switch.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Removing the back of the dryer
to get at belt you will need to get true the front of dryer.When you have top up there should be 2 screws on both inside corners on front panel remove them and lift up and towards you the front panel should come off.After that look under drum .Sounds like your belt sliped off the idler pully you can then put belt back on and reverse the steps.If any more help needed feel free to ask hope i fixya:)
May 21, 2009 | Kenmore 64852 Electric Dryer
Dryers Logo
49 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
