Question about Whirlpool Calypso GVW9959K Top Load Washer
Error message CE displaying. Machine will not run.
  • 2,382 Answers
Hi, concerning the CE error, the tech sheets indicate this is a problem with the motor control board with a blown fuse on the board. The solution is to replace the board....
Posted on Oct 01, 2010
CE error displays
hello there and thank you for choosing fixya
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Jul 31, 2011 | Washing Machines
I am trying to sew with the machine and get a beeping sound. I have rethreaded several times all with the same results. Also where do the error messages display?
I do not have access to a manual for this machine.
Look through the back, near the maintenance section of the manual for the error message codes and where to view them.
Apr 10, 2010 | Singer CE-200 Quantum Futura Computerized...
The washing machine displays error code CE for communication error
Hi, Well if there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
1.Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
2.Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
3.Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
4· Drive motor thermal protector has opened.
5·Motor controller is not powered or fuse has opened. Replace motor controller.
I hope it helps. Thanks! mannu_rakesh
Sep 02, 2009 | Kenmore Washing Machines
My whirpol calypso washer don't running, appear fl and ce
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
• Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
• Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
Mar 08, 2009 | Whirlpool Washing Machines
Kenmore Elite Top Loader "CE" error code.
CE means communications error
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Error message E4
All sewing machines are 'picky' about being threaded correctly. As you seem to understand. There is no shame in asking the seller for help.
Jan 23, 2018 | Singer CE350
KEEPS SHOWING A BROKEN TREAD ERROR MESSAGE. I CANOT FINISH A PROJECT! SINGER FURURA CE-150
I have a CE-250 and I was having problems getting this message. After doing some research, I discovered that it was the thread sensor not sensing the thread. Try rethreading it or cleaning out your sensor area. It works for me when I get this message
Apr 23, 2008 | Singer CE-100 Futura Computerized Sewing...
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
