Question about Samsung YP-U3 MP3 Player
The light keep flashing ,my computer cannot scan it
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
Try reinstalling it to your computer. Does you model have the "Auto Scan" feature? If it does, this link explains how to use that feature. http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=40&PG_ID=0&AT_ID=268355&PROD_SUB_ID=0&PROD_ID=46&EMAIL_ID=40. If this does not help, check your PC specifications and see if they match up with your MP3 player's specification needs. It may be that your MP3 player cannot work on your computer because you don't have the right specifications on your computer that the it needs to have in order for the MP3 player to work on it. Here are the Specifications:
  • Pentium 300MHz or higher.
  • USB Port 2.0
  • Windows 2000/XP/Vista
  • DirectX 9.0 or higher
  • 100MB of free hard disc space
  • CD Rom Drive (2X or higher)
  • Windows Media Player 9.0 or higher
  • Resolution 1024 X 768 or higher
  • Internet Explorer 6.0 or higher
If this does not help, try resetting the system. Push the "HOLD" button in the direction the arrow is pointing to. Press and hold briefly the "User/Recording" and the "Play & Play/Pause" buttons at the same time. This will not affect your settings. You should organize the files and folders, as this makes scanning easier.
Your batteries might also be an issue. Maybe you need to recharge the battery.
I also have the link for the user manual, where I got some of this info from. http://downloadcenter.samsung.com/content/UM/200709/20070918092735125_YPU3-COMMON-ENGLISH1.0.pdf
Posted on Oct 01, 2010
The engine is "chugging" and running very rough and sluggish. the engine light keeps flashing
you need to take to autozone or advance and let them check the computer codes. if the engine light is flashing the codes stored in computer will help if not outright identify problem..they will check codes free of charge
Sep 28, 2015 | 2008 Ford Ka 1.3
Why does my o/d off light keep flashing
You have a problem with you transmission , the flashing light indicates that there is a code stored in the engine or transmission computer module !You need to have the module scanned with a diagnostic scan tool .
Jan 20, 2015 | Cars & Trucks
I have a 2000 suzuki esteem and check engine light is on. the o/d light keeps flashing but no problem with the car shifting
You would need to have the computer scanned for trouble codes to proceed.
Most auto parts stores will scan for free in hopes of selling you parts you may or may not need. The codes are a guide to what you should test not replace.
The flashing O/D light could mean the computer has a problem with the transmission or the engine is not able to use overdrive.
Jan 14, 2013 | 2000 Suzuki Esteem
D light keeping flashing even when vehicle is in park
The "D" light blinking indicates an issue in the transmission. If it is still driving fine then the most common issues would be a pressure switch is faulty. You would need to have the computer scanned to retrieve the trouble code and then you will be able to tell exactly what is going on with the transmission. Most advance auto/auto zone stores will scan the computer for free. typically a pressure switch is around $65 and take 1/2 hour to install.
Hope helps.
Jun 08, 2011 | 2002 Honda CR-V
Flashing check engine light
Flashing is bad, the engine is misfiring....you may have already damaged the cat converter by driving that way. Get it repaired before more damage is done.
May 11, 2010 | 1997 Nissan Maxima
Had the engine replaced in my 99 explorer and now the overdrive light keeps flashing
The overdrive light also serves as the "check engine" light but for the transmission. If its flashing it means the computer recognizes a problem with the transmission or its electronics. If the engine was just replaced, they probably forgot to plug something in, or some wiring got damaged in the engine swap. It can be scanned with a scan tool for a code and the code will indicate what circuit is at fault.
Apr 23, 2010 | 1999 Ford Explorer
Air bag light keeps flashing
you have a failure in system need scan to see computer code for fix. with light flashing or on air bags will not deploy in a crash.
Feb 10, 2010 | 1996 Nissan Maxima
MX318 fails all fax functions
If you are using only one incoming telephone line, you need tro reset your printer at 'fax priority' position onn your printer. An MX-typr handicap.
Sep 20, 2009 | Canon PIXMA MX310 All-In-One Printer
"check engine" light flashing
Take the car to an autoparts store and have them scan the computer for fault codes. Most parts stores will do the scan for free. The check engine light is to alert you that the computer has identified a fault in one of the car's systems. Getting the codes will show what the computer noted, so a problem/potential problem can be addressed. Hope this helped and best wishes.
Sep 06, 2009 | 1999 Suzuki Vitara
Engine check light keeps flashing
Take the car to an autoparts store and have them use a scan tool to retrieve the codes from the computer. Most part stores will do the scan for free. The check engine light comes on to indicate that the computer has noted a fault in one of the car's systems. Getting the codes will show what faults the computer has noted and what system is affected. Hope this helped and best wishes.
Aug 28, 2009 | 2001 Daewoo Lanos
Samsung YP-U3 MP3 Player Logo
59 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
