Question about D-Link Xtreme N DIR-655 Wireless Router
How do I select the router/computer channel? - D-Link Xtreme N DIR-655 Wireless Router
  • 33 Answers
Well in ROuter u have an Option Wireless Transmit Channel
by Default it has been Set to Auto
u can Change it to either 1 or 6 or 11, Which are Non Interfering Channel and Will Provide Better Signal Strength
All the Best
Posted on Oct 01, 2010
Netflix member log in
you need router wich support openvpn check your router model number with dd-wrt.com and see if you can change the frimware and get openvpn software on it , if this compatible then you need vpn account you can grab from http://www.overplay.net/#a_aid=vpnprovider
May 02, 2014 | Netflix
Tip
How to achieve 300 Mbps speed in N standard routers ?
To achieve 300 Mbps speed in N standard routers:
In order to achieve 300Mbps speed between router and your wireless computer you must have an N standard router from belkin and also the wireless adapter on our computer should be an N standard (802.11n).
If you fulfill the above criteria then you can follow these simple steps to achieve 300Mbps speed between your computer and router.
  • Connect any Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox any of your web browser (chrome will not support).
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Step 1: Wi-Fi Protected Setup (WPS)
In the Belkin router Setup page, on your left hand side, you will have Wi-Fi Protected Setup (WPS) below WIRELESS. Click on Wi-Fi Protected Setup. If it prompts you for a login password, leave it blank and Click on Submit.WPS will be enabled by default. Change it to Disabled and Click on Apply Changes. It may or may not take some time to save the Information and brings you back to the same page.
Step 2: Security
Select Security found on left side of router setup page.Security mode will have the following options,
  • WPA / WPA2 (PSK)
  • 64-bit WEP
  • 128-bit WEP
  • Disabled
Now select this way.....
  • Select the security mode as WPA/WPA2.
  • Select the authentication type as WPA2.
  • Select the encryption type as AES.
Then you will be able to see the pre-shared key (PSK) or passphrase (PSK), in this box you need to type at-least 8 characters as the network password.
After typing the password you can verify the password by un-checking obscure PSK. Password is case sensitive. Once you are done check obscure PSK and Click on Apply Changes.
You need to enter the same password in your computer to get connected to your wireless network.
Step 3: Channel and SSID:
Once you are done with that select Channel and SSID found on the left side of RSP.
Change the Wireless Channel to 1 or 6 or 11 (these are the best non-overlapping channels for wireless networks).
Change the SSID to any name as you wish, this will be your wireless network name (I recommend you to use a single word of any length. It can have letters, numbers or combination of both).
Check whether the option Broadcast SSID is checked / enabled (it must be enabled).
Protected mode should be OFF.
Bandwidth should be selected as 20/40 or 20+40 MHz
Once you are done click on Apply Changes.
Now connect the computer to your wireless network.
It will be connected at a speed of 300Mbps.
click here to know how to connect to the wireless network....
on May 19, 2010 | Computers & Internet
Belkin router ssid does not show up
Try checking on this.
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on "Channel and SSID" in the left-hand column under the Wireless heading.
  6. The router may be set to auto for the channel selection. This means that the first time the router is powered on, it will automatically select the channel that has the least amount of interference. As surrounding networks are added, the initial channel may become crowded. Use the drop-down list and select a new channel for your router.
    Note: Channels 1, 6, or 11 are the best selections.
  7. After setting the channel, select the SSID box by clicking in it.
  8. Type a name that is familiar to you. This is the name of the wireless signal on which your router will broadcast.
  9. Once these changes have been made, click the "Apply Changes" button toward the bottom of the screen.
Mar 10, 2011 | Belkin (F5D8235-4) Wireless Router
How do I change the frequency of my router
Here are the steps to change frequency:
1. Open a web browser and type the IP address of the router into the navigation bar. For most routers, the IP address is 192.168.1.1.
2. Enter your username and password into the prompt. This is the administration password to access the router's console.
3. Click the "Wireless" tab. Select "Basic Wireless Settings." This opens a window with a "Channel" section. This section is where frequency settings are changed.
4. Select channel 1, 6 or 11. These channels provide the clearest signal since they do not overlap other channels. Click the "Save" button and close the browser window.
5. Reboot the wireless computers. A change in frequency drops wireless devices from the network. The computers need to be rebooted to find new network settings.
Nov 08, 2010 | Computers & Internet
I need to change the channel settings on my RCA DCM425 cable modem. The problem is my company set up the router and wireless along with an ASA and I do not have any of the original information. How do I...
Cable Modem Troubleshooting RCA DCM425
or
You can change the radio channel on your AirPort Extreme using the AirPort Utility, as follows:
  • Run the AirPort Utility.
  • Select the AirPort Extreme, and then, select Edit.
  • Select the Wireless tab.
  • Select Wireless Options.
  • By default, the channels for both the 2.4 & 5 GHz radios are set to "Automatic." You would first change this to "Manual," and then, select the desired channel.
Oct 10, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Belkin N150 routerlooses connection when microwave oven is turned on.
HI ..,
The router would drop the wireless signals if you have any cordless phone,microwave.. .. so keep the router a little far away from the kitchen and wireless devices .. or else you can try changing the wireless channel to no 11 or 9 or 6 are the best wireless channel below is the steps
Wireless routers can broadcast on several different channels, similar to the way radio stations use different channels. In the United States and Canada, the three main channels are 1, 6, and 11. There are more channels on the router, but they "overlap." Similar to how you'll hear interference on one radio station while another is perfectly clear, sometimes one wireless channel is clearer than others. You don't need to change your computer's configuration, because it automatically detects the router's new channel.
In order for a wireless device to connect to a wireless network, it must know the network name, or SSID (service set identifier). If you plug your wireless router or access point in and leave the default SSID, it won't take long for an attacker to determine what the SSID is.
To change your channel and SSID:
Sep 26, 2010 | Belkin Computers & Internet
My internet signal keeps going in and out. It is difficult to do anything. The internet and wireless lights are blinking on the router. Is the blinking normal?
blinking is normal coz it tells you that you have connection betwwen your computer and router. you have to check your ISP for the intermittent connection that you are getting. there might be reported problem in your area or there is a downtime in your ISP.
Mar 25, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How to change channel on actiontec router
Log in to your router. Select Wireless Setting then Basic Security Settings. Item #3 is the channel. Select the channel you want, then select Apply at the bottom of the page, et voila, you'll have your new channel. Good luck getting a better S/N ratio.
or follow this link
wordnet.princeton.edu/perl/webwn?s=tune
Nov 13, 2009 | Actiontec (GT704WG) Router
D-Link AirPlus DI-524 Wireless
Yes you can change the router channel. Log into the router at 192.168.1.1. If you have not been here before the default username/password will be admin/admin. Check under your wireless settings which channel is selected and try another. They will all default to channel 6 I think. If a neighbour has the same router with the same default this could be causing your contention problems. You can download a manual for your router at www.dlink.co.uk. Good luck.
Dec 15, 2008 | D-Link AirPlus DI-524 Wireless Router
What do I do if the Throughput is not 108Mbps?
1. In the routers web-interface, click on login (password would be either blank or smcadmin) -> home network settings -> wireless -> channel and SSID. 2. In channel and SSID go to wireless mode and select the option 'dynamic turbo' and apply the settings. 3. Now turbo cards can connect at 108 mbps with turbo router in the wireless computer.
Feb 19, 2006 | SMC Barricade 7004 Router
D-Link Xtreme N  DIR-655 Wireless Router Logo
245 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
