Question about Marantz SR-7200 Receiver
Having trouble setting up sound system
We have a marantz sr7500 sound system and are having major problems getting the back surround sound speakers to work. we have read the manual have reset to system back to the beginning if that makes sense. seem to have the rest working fine i think but seriously need help.. otherwise i think it may end up out the window.
thanks to anybody who can help.
  • 171 Answers
I can see by the setup of this device, it can be confusing. So let's make sure you are setting the device to the correct "A" speaker outputs. These would all be on the rear panel, on the right side of the receiver. Is this correctly setup?
Posted on Sep 25, 2008
  • Todd Gale
    Todd Gale Sep 25, 2008
    To select the surround mode during playback,
    press the AUTO button on the front panel.
    (Using the remote control unit)
    To select the surround mode, press the AMP
    button and press the > button until PAGE1 is
    displayed. Press the AUTO (D1) button
    VOLUME
    control knob on the front panel or VOL
    buttons on the remote.
    To increase the volume, turn the VOLUME knob
    clockwise or press VOL button on the remote, to
    decrease the volume, turn counterclockwise or
    press VOL button on the remote.
    Notes:
    • The volume can be adjusted within the range of –
    ∞ to 18 dB, in steps of 1 dB.
    • However, when the channel level is set as described
    on page 20, if the volume for any channel is set at
    +1 dB or greater, the volume cannot be adjusted up
    to 18 dB.
    (In this case the maximum volume adjustment
    range is “18 dB - Maximum value of channel level)
  • Todd Gale
    Not everything will play in surround mode, as not everything is produced in surround mode, so make sure run the speaker test to verify the speakers are working in surround mode and the adjust the volume of each according to the distance and depth you desire.
    This sub-menu is to adjust the speaker levels for
    7.1-channel input sources.
    Here you will adjust the volume for each channel so
    that they are all heard by the listener at the same
    level.
    1.
    Select “7.1CH INPUT” in the SETUP MAIN
    MENU with the or cursor buttons, and
    press the ENTER button.
    2.
    To select “VIDEO IN”, press or cursor
    button.
    3.
    Using the or cursor buttons, select the
    video input source which is emitted from
    Monitor out in the 7.1 CH INPUT function.
    The input source is switched by pressing the
    or cursor buttons as follows;
    LAST ↔ TV ↔ DVD ↔ VCR1 ↔ DSS ↔
    AUX1 ↔ V-OFF ↔ LAST ↔
    Notes:
    • When select LAST, the source is set previous
    source before 7.1 CH INPUT function is activated.
    • When select V-OFF, no signal is emitted from
    monitor out terminal.
    4.
    To Select desired channel , press the or
    cursor buttons.
    5.
    Using the or cursor buttons, adjust the
    volume level of each channel.
    6.
    After you complete this portion of the set up,
    move the cursor to “MAIN” with the or
    cursor buttons and press the ENTER button.
    Notes:
    • These settings will be memorized to 7.1CH INPUT
    source.
    • This feature can be directly selected with the
    CH.SEL
    button of the remote controller.
    7 7.1 CH INPUT LEVEL
    V I DEO I N : LAST
    F RONT L : 0 dB
    CENTER : 0 dB
    F RONT R : 0 dB
    SURR . R : 0 dB
    SURR . B R : 0 dB
    SURR . B L : 0 dB
    SURR . L : 0 dB
    SUB W : 0 dB
    MA
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink - http://www.we-supply.com/browse.cfm/optical:-audio/2,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Austin
www.we-supply.com
Aug 08, 2013 | Audio Players & Recorders
No surround sound
you may have a connection problem if its new take it back if not then try to make sure all wires are tight and secure if it still does it then it also could be the settings because on most surround systems you cann turn on and off individual speakers or select what speakers play and which dont refer to your owners manual
Dec 18, 2009 | Marantz SR5001
Protect error on marantz sr4200
Check all your speaker wires carefully. Chances are good that a braid has crossed from + to - and causes the unit to protect itself. This is a very common problem! everyone's done it at some point. Check connections at both the receiver side and the speaker side. If you still have a problem, post a comment and I can help you troubleshoot further. Hope this helps.
Sep 27, 2009 | Marantz SR7500
Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Feb 26, 2009 | Marantz SR7500
Marantz Surround SR7500 Receiver (don't know if anyone has this model)
Hi 3303k
Strange dramas you are having there. I would suggest first, that you switch the unit off overnight(unplug at the wall) to allow for a fulll hard reset. Then fire it up in the morning again, and see if it behaves itself. I found a user manual for you online here
It is a good amp that you have, and hopefully resetting it will sort it out for you. If not, please do get back to me here and we shall look deeper..
Thanks for using FixYa, a FixYa rating would be great for looking into this for you. Happy to help further :)
regards
robotek
May 08, 2008 | Marantz SR-7400 Receiver
I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Feb 05, 2008 | Marantz SR-5200 Receiver
Polk Audio RC55i In-Wall Surround Speakers (can't hear whispers)
I'd make sure that the receiver surround mode is set for one of the digital settings, such as Dolby Digital or DTS, and make sure that you have the center channel level adjusted to a level similar to the other two front channel speakers. I've seen/heard this happening when using dolby digital material & having surround set on something like 'hall' or 'stadium' or dolby surround, where only 4 channels are used & the amp has to 'mix' sounds to the left & right front speakers. It'll often sound like the actors on screen are talking out of the bottom of a barrel, with a hollow & tinny character to the voices.
Jan 07, 2008 | Polk Audio RC55i Main / Stereo Speaker
Marantz SR-7200 Receiver Logo
226 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
