Question about Roper RES7646KQ Electric Dryer
Dryer wont spen
How many belts are on a roper dryer. onlythree years old motor comes on but it wont spin it has a belt in the middle but is thier suppose to be one on the back as well if not what do you think the problem might be
  • 525 Answers
The dryer only has the 1 belt that drives the drum. Shock Hazard Warning! Remove the dryer from its power source before accessing internal components.
Look for an obstruction in the blower which is attached to the front of the motor. Look for a foreign object stuck between the drum and bulkheads. Inspect for a broken belt. Inspect all drum rollers for free operation. Inspect idler pulley on rear of motor for free rotation with belt removed. Inspect drive pulley on rear of motor. All this can be done through the front of the dryer by removing the front panel enclosure.
Hope this helps!
Posted on May 26, 2008
I have a 9 year old Roper dryer. Went in today to turn it on and the motor sounds like its running, but there doesn't seem to be anything turning and I hear a high pitched squeaking sound. Any thoughts??
The problem is likely the dryer belt . Here is a video Dryer belt replacement video . It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Feb 21, 2011 | Roper REX4634KQ Electric Dryer
Roper dryer model REL4434AWO has stopped spinning. Heating element works. Belt seems secure around drum.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 18, 2010 | Roper Dryers
My dryer won't turn. The motor runs when you push start but the drum doesn't turn. I can turn it by hand and it will run.
- The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
- The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
- The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
- Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Dec 15, 2010 | Dryers
Drum dose not turn.
sounds like the belt or motor, need to take it apart, the belt should be in the middle of drum if it is then more the likely it is the motor, you can disconnect belt pug dryer in and see if the motor spins, there may be a reset on the motor, if so it is located where the wire come in. Here is a website that that will help with the cabinet removal and some other things that could cause the problem:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 25, 2010 | Amana ALE643RB Electric Dryer
Have a rope model red4440vq1 electric dryer. it is about 5 months old. the the dryer is heating but not spinning
Aha Broken belt. You would need to get inside the machine to investigate the problema. If you were drying some big old tennis shoes that would knock the belt off. I have a pictorial on this with a manual and a nice video prepared by Repair Clinic HERE
Oct 08, 2010 | Roper REX4634KQ Electric Dryer
Dryer gets hot but wont spin
could need a belt or motor bearings for the tumbler
Sep 19, 2009 | Roper REX4634KQ Electric Dryer
The dryer is humming but not spinning when i removed the top cover i see the belt in the middle of the drum. Do you know where it supposed to go?
is belt disconnected? Is belt broken? Will dryer rotate manually? if so ,
I suspect that the belt broke. order a new belt Home depot has a good parts service or try other local appliance places. You will have to disconnect power first, Remove front panel to access drum Dont forget to unplug door switch there should be a plug front top right, in the rear on the bottom there is a motor and an idler/tensioner. install the new belt and under tensioner Yes the path will seem awkward and re assemble. Also now is the time to vacuum lint out
Dec 30, 2008 | Roper RGX4634KQ Gas Dryer
Dryer wont spin
Take the back off  of the drier after unplugging and the beklt goes from the motor pully all the way around outside of the the drum.You can't miss it. Most of the Kenmore drier belts are the same. WE have apliance repair parts stores locally.If you also do , go to the store with the old belt and match it up.
Dec 19, 2008 | Kenmore 63942 Dryer
No spin on a roper
This machine does not use a belt. It has what is called a motor coupler between the motor and transmission. This is not the first place to check. I'd be looking at the lid switch first. This machine will not spin if the switch is faulty.
Dec 17, 2007 | Roper RAS8445KQ Top Load Washer
Roper RES7646KQ Electric Dryer Logo
66 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
