Question about Garden
I m using a normal 9V, 1 amp adaptor for my boss me 70... bt d sound of the boss me is nt lyk dat hw it is in its demo videos.... i tried every result... n also m using ibanez grg170dx wid humbuckers... plzzz let me knw d actual problem... Also m nt able to understand the output ports....wen i set my tone wen connected by recording o/p it sounds....bt wen i connect d same wid d stereo port....it sounds different.. plzzz as soon as possble....giv me some solutions.... regards.. ananth
  • 263 Answers
SOURCE: No sound Acer Aspire
go to control panel then to the sound and devices then open it and see if the box has been check on mute if that is the case remove the check mark and press apply if not check the box place the volumen icon in the task bar and then do apply,,,this will put the spaeker icon in the battom right to the screen next to the time clock click on it and set the volumen as you desire by drag up the volumen bar rate me fixya
Posted on Jan 13, 2008
  • 15 Answers
SOURCE: Headphone jack broke off inside
yes, you could easily open the computer and physically remove the wires from the mother board for the front audio jack. These are pin headers. Most all the time they are labeled.
The rear audio should already be working from the green jack. If not, then perhaps you have the RealTek Audio chipset and software. The realtek audio software generally has a orange speaker icon in the system tray. You can double click to open it, go to the Audio I/O tab and then click the little wrench icon. It will open the connector setting. On the connector settings screen is a checkbox. Disable front panel jack detection. Uncheck that, also a check box for Mute rear panel output when fron headphone plugged in, UNCHECK this. That should do it.
If you want to try further to remove the broken jack make sure the machine is off, use a very tiny needle nose pliers (electronic type) you should be able to pull it out.
What kind of computer do you have? You could also possibly remove the jack assembly from the inside, so you can get a better view for the extraction of the plug.
b
Posted on Dec 13, 2008
  • 1138 Answers
SOURCE: humbucker not sounding
If you have a volt ohm meter, try unsoldering one lead from the pickup in question making careful note of where it was unsoldered from. Use one probe on the other wire or wire that aren't unsoldered from that pickup. Use the other probe on the end of the wire you unsoldered with the volt/ohm meter set to a setting which can cope with between 3 and 14 k. Generally the resistance will read between 3k and 14k. A shorted pickup will read considerably less but there will still be a reading. If your pickup is dead there are 2 possibilities. One is that a winding in the pickup is burnes out or broken and you will get no reading with the resistance test. The other which is rare but not impossible is that the magnet in the pickup has lost its flux which means that you could have weak to no sound. There are other possibilities such as your pickup being adjusted to low to sense the strings. If none of this helps if you can, try www.seymourduncan.com.There are wiring diagrams and lots of good info on this site.
Posted on Apr 28, 2009
cormoncable
  • 51 Answers
SOURCE: Sharp Aquos LC-32GH5 and MacBook problem, HELP!
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: tis openin d fb login page everytyme m tryin to log in
hmmmm i think ur accnt has been hacked n the only way that can serve the purpose is that rehack it or reset your fb password. . bext ov luck
Posted on May 21, 2010
My Boss ME-70 han only two dots when i power on ,pedals dont lit when i press it down, is there a solution with this?
PDF]BOSS ME-70 Training Guide - Roland
cdn.roland.com/assets/media/pdf/ME-70_Training_Guide.pdf
AC adaptor. • $418.50 List, $299 MAP ... Connect the ME-70 to power using a BOSSPSA-120S AC Adaptor. 4. Plug a guitar into the ... For illustration only ). 4. Press the ...1. Turn the MODULATION TYPE knob to select a Modulation effect. Do not ... 2. Pressboth pedals down again or press EXIT to return to Manual Mode.Missing: han ‎dots
ME-25 Guitar Multiple Effects Review ' Boss ' Guitar Effects ...
https://www.ultimate-guitar.com/.../boss/me-25_...
Ultimate Guitar Archive
Rating: 8.6/10 - ‎135 votes
Sep 16, 2015 - Overall the effects are very very full sounding and don't sound too digital by any means. ... With 2 selector pedals, up and down, its a pain in the ? ... Editing the patch is as simple as press 2 buttons at the same time and turning ... If this was stolen I would probably get the ME-70 just because it pretty much ...
Tom Scholz's Guitar Sound - Van Halen Links.com
Jan 06, 2016 | Roland Boss ME-70 Guitar Multiple Effects...
My boss me 25 pedal's sound isn't as clear and good as the demos' sound. My amp is a randall RT100 which is a valve amp and my guitar is an LTD with the custom pickups. so the problem is the setting i'm...
I have the Boss ME 50. Here's things to try. Use wall outlet to power the 25 instead of batteries. Have volume on amp up, volume on pedal all the way up, volume pedal all the way up(depressed), no gain on amp(use clean channel or clean setting if only 1 channel)effects on amp off(reverb, chorus, delay, boost, etc.) mid range knob below 5. only 1 pickup on, guitar tone knob all the way towards treble. If this puts you in the ballpark you can then make slight tweaks to any of these settings. What we're trying to do is not run a dirty sound from the pedal board into an amp with dirty settings. That double dirt often causes a muddy sound. Aside from that you can back off on various effects in the patches. My 50 has a list of the patches and factory settings, so if the drive, for example is set on 8, I might back it off to 4, or the compressor, or the delay, etc. If you like the sound save it. If not continue on. Start with the amp 1st. Higher output tubes(such as JJ's produce a cleaner sound. Also the demo you heard was not coming from your guitar speaker which may not be on the clean side.
Sep 25, 2017 | Roland Boss ME-25 Guitar Multiple Effects...
The Auto on my Boss RC2 sometimes doesn't seem to pick up a signal and engage. It is plugged into a multi- socket adapter and I do not have the amp turned up too loud as the room is tiny. I thought it was...
Sometimes, with BOSS pedals, the battery must be disconnected before using another power source. I ran into the same problem with my DS-1 distortion. If it's not that, then check the power rating of the power adapter. It should read, for the output, exactly 9V DC. If it doesn't, then you have to get a power adapter that has that same rating. Boss pedals will not use anything other than 9V DC (I know, I've tried).
Hope that helps!
Mar 26, 2011 | Roland Boss RC-2 Loop Station Stompbox...
I hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any...
i hv windows7 ultimate in my computer bt its activation has expired. On desktop its written dat this copy of window is nt genuine. So wat to do further to get my system error free. Kindly suggest any solution so dat i may nt loss my data and free. inf me on y email shin_dragon_pke@yahoo.com help is need ASAP
Jul 02, 2010 | Computers & Internet
Tis openin d fb login page everytyme m tryin to log in
May 20, 2010 | Facebook Social Network
My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Apr 01, 2010 | Boss Mt 2 Metal Zone Effects Pedal
Help
That is the specs of the ac adaptor that the X Rocker Chair uses to power the speakers on.
It uses a 10 Volt Ac Adaptor that runs off of 1.2 amps.
May 28, 2009 | Pyramat Sound Rocker Gaming Chair
When upgrading
wi-fi on my phone is not working.
Nov 01, 2008 | Apple iPhone Smartphone
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
