Question about Hampton Bay 24750 Huntington III Ceiling Fan
Fan is vibrating and is waking me up. I think its from the light cover. How can we stop this?
  • 490 Answers
The cover should not make noise if all the screws are snugged down, but in the event it is malformed, you can remove it and make a small gasket with electrical tape between the adjoining parts. Doing this on the very rim should make it not show from the outside and reduce noise from vibration. Farmerbear at FixYa.com
Posted on Oct 01, 2010
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Oil Is Leaking Out Under The Harminc Balancer On my 92 Jeep Wrangler,4.0 6cyl. I Replaced The Main Seal & Put A New Balancer On & It Still Leaks From The Bottom Of The Balancer
  1. timing cover is leaking oil betwwen cover and block
  2. Disconnect the negative battery cable.
  3. Remove the drive belt(s), fan and fan shroud. If equipped, remove the accessory drive belt pulley.
  4. Remove the vibration damper retaining bolt and washer. Remove the vibration damper using a suitable puller.
  5. Remove the accessory drive brackets attached to the timing cover.
  6. Remove the A/C compressor, if equipped, and alternator bracket from the cylinder head and move to one side.
  7. Remove the oil pan-to-timing case cover bolts and the cover-to-cylinder block bolts.
  8. Remove the timing case cover front seal and gasket from the engine.
  9. Cut off the oil pan side gasket end tabs and oil pan front seal tabs flush with the front face of the cylinder block. Remove the gasket tabs.
  10. Clean the timing case cover, oil pan and cylinder block gasket surfaces.
  11. Remove the crankshaft seal oil seal from the cover by prying it out with a suitable tool.
To install:
  1. Install a new seal in the timing cover using a suitable seal installation tool.
  2. Apply sealer to both sides of the replacement cover gasket and position the gasket on the cylinder block. Cut the end tabs off the replacement oil pan gasket corresponding to those cut off the original gasket. Attach the end tabs to the oil pan with sealer.
  3. Coat the front cover seal end tab recesses generously with sealer and position the seal on the timing cover.
  4. Apply engine oil to the seal-oil pan contact surface, then position the cover on the cylinder block.
  5. Insert timing case cover alignment tool J22248 or equivalent, in the crankshaft opening. Install the cover-to-cylinder block bolts and tighten them to 62 inch lbs. (7 Nm). Install and tighten the oil pan-to-cover bolts to 11 ft. lbs. (13 Nm).
  6. Remove the cover alignment tool and position a replacement oil seal on the tool with the seal lip facing outward. Apply a light coat of sealer to the seal and a light coat of oil to the crankshaft. Install the seal on the timing cover.
  7. Apply a light film of oil to the vibration damper hub seal contact surface. Install the vibration damper using a suitable installation tool.
Do not hammer the damper into place as damage may result to the damper or engine.
  1. Install and tighten the crankshaft vibration damper bolt to 80 ft. lbs. (108 Nm).
  2. If equipped, install the crankshaft pulley and tighten the bolts to 20 ft. lbs. (27 Nm).
  3. Install the accessory brackets.
  4. Install the fan and fan shroud.
  5. Install the drive belt(s) and adjust to the proper tension.
  6. Connect the negative battery cable.
  7. Start the engine and check for leaks
  8. .
Jan 18, 2011 | 1992 Jeep Wrangler
The glass light cover falls off when the fan is on. I have made certain that the cover was screwed in properly but the vibration of the fan loosens the cover. Any suggestions?
I would first tighten any screws that might be part of the vibration problem. They do work loose. As far as the globe goes, sounds like you might need some kind of spacer material between the glass globe and the frame it screws into. Perhaps a few pieces of small clear plastic hose. Try and wedge them between the globe and metal frame when screwing the globe back on. Make sure it is snug, but do not over tighten to the point where the globe breaks.
Aug 27, 2010 | Casablanca Fan Stealth 3211T Ceiling
Excessive noise
mcdevito75, here, It could be the sealed bearing in the fan motor, shut off fan and see if the noise goes if so you"ll need an A/C repair shop to look at the unit, they come to the house, if it"s not the fan it may be vibration and the front cover where the switches are is loose and makeing the noise, gently press on this front cover and see if the noise stops, if so use Duct tape around the edges to hold that cover tight on the unit.
Jun 24, 2010 | Frigidaire FAC125P1A Window Air...
My head lamps and stop lights keep going out almost every 2 to 3 weeks at a time
Check your charging voltage. Run the engine at 1,000 to 1,300RPM with the light, AC, and ventilation fan off, and measure the charging voltage. Should be 13,8 to 14.5. I think it is probably fine, but check that first.
Premature failure of lights is most often caused by vibration. If the lights are not held firmly enough they will vibrate, and destroy the filaments.
Jun 23, 2010 | 2004 Chevrolet TrailBlazer
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
Noise from the fan/fan motor
The bushings in the motor are worn out, replace motor. This should correct the problem.
Sep 10, 2009 | Refrigerators
99 clk heavy vibration when stopped at a light
Have your Motor Mounts and Tranny mounts checked.
Jun 24, 2009 | 1999 Mercedes-Benz CLK
Faint noise on booting.
Try this remove side cover and boot computer listen for any extra noise fan etc. also by power supply
As I think you have a bad bearing in a fan
To temp fix it
remove paper cover over center of fan and put a small and I mean small drop of light machine oil on bearing then replace paper cover.
check if this stops the noise if it does you know which fan to replace.
If it is power supply fan and if you think yourself capable remove fan and do the same to it
Oct 13, 2008 | Intel Motherboard
Hampton Bay 24750 Huntington III Ceiling Fan Logo
61 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
