Question about Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery
Will this charge 2450 mah battery? - Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery
  • 24 Answers
Yes, this will charge any AA-AAA Batteries. Typical charge will be about 14 to 18 hours
Posted on Nov 07, 2010
Can 1.2Vlt 800 mAh battery 1.2 volts instead of 630 mAh battery used in this device? ..
Hi
There should be no problem at all. The designations you show are both for 1.2 volts. The mAh specification refers purely to the capability of the rechargeable to deliver current over a period of time. 800 mAh will deliver 800mA for 1 hour or 400mA for 2 hours. Hence the 630mAh battery under fully charged condition will not last as long as the fully charged 800mAh battery when supplying the same current in the same application.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 30, 2014 | Cameras
Supertooth disco speaker issue
You need a new battery that supplies the full 2400 mah to unit. Batteries do wear out and the 1800 mah is not going to cut it.
Aug 24, 2017 | Audio Players & Recorders
The 4775 unit seems to take a charge but it does not run? It's making a light buzzing sound? I've opened the unit, checked the batteries and they seem fine?
If the unit is more than a year old, the batteries may well be dead...you would need a tester to measure the charge in the batteries. It's cheap to change them.
The shaver is easy to open:
http://johnfixesstuff.blogspot.ca/2013/02/how-to-replace-batteries-in-braun-4775.html
I used 2 garden variety Eveready 2450 mAh NiMH rechargeables from Super Store...NiMH because I had them on hand.
They're a tad short, so I inserted some folded aluminum paper on the Negative ends to take up the slack...done.
The batteries fit solidly in place.
Shaver worked immediately, and is behaving normally while plugged in to recharge (green LED steadily lit as it should be).
We'll see how the NiMH batteries do in the NiCad charger. I can always replace these batteries with NiCad's.
Feb 03, 2013 | Braun 4775 Electric Shaver
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
No matter what batteries I buy camera will no longer take a pic.
This camera is noteworthy for this problem. Only non-rechargeable batteries seemed to work, and that gets expensive! But the solution for me was simple. You have to spend a little more money upfront, and get high capacity (e.g. 2450 mAh) batteries. You should be able to get those at Target or Walmart. The 2100 mAh ones just won't do the job.
Using the cheap, low capacity rechargeable batteries, I could only get a few shots off. With the high capacity ones, I can do 40 or so easily.
May 12, 2009 | Olympus FE-210 Digital Camera
Hp 435 digital camera battery
The NI-MH batteries are the Best for use with Digital cameras....U need to Charge the New Battery for 12 Hours The First time and then 2-3 hours for every other time you charge ... try and check please
Oct 14, 2008 | HP Photosmart 435 Digital Camera
Initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Oct 09, 2008 | Sony AA Nimh 2500 Mah Rechargeable Battery
Very short battery life
For the FE-210, infamous for its odd battery problems, insert 2 LI batteries, set quality to sq2, DONE, or i was lucky
Aug 03, 2008 | Cameras
Duracell AAA NiMH Battery Charger with 4 Rechargeable AA Battery Logo
387 people viewed this question
Top Duracell Electronics - Others Experts
Craig Butler
Craig Butler
Joseph Mueller
Joseph Mueller
Are you a Duracell Electronics - Other Expert? Answer questions, earn points and help others
