Compute the torsional shear stress in a hollow shaft with an outside diameter of 40 mm and an inside diameter of 30 mm when transmitting 28 kilowatts(kW)of power at a speed of 45 rad/s
  • 4 Answers
SOURCE: blower runs fine for 30 or 45 mins, then will not come up to speed.
there is a fuel filter in the fuel tank that some times gets cloged try that and fresh gas -oil mix
Posted on Feb 05, 2009
  • 45 Answers
SOURCE: Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Posted on Apr 29, 2009
proartya8765
  • 581 Answers
SOURCE: I just purchased a factory serviced model TR-520
Satisfaction Guaranteed on all orders:
We are happy to fully refund purchases if an error has occurred in your order or if an item you ordered is defective. If you aren't happy with the product you received or are dissatisfied for any reason simply return the item within seven days for a full refund minus a 15% restocking fee. Please call us or email us within seven days of receiving your order for information on where to ship items that need to be returned. Do not return them to our P.O. Box.
The returned product must be in new and unused condition, in the original box with all the documentation, parts and accessories to insure full credit. "New and unused" means sale-able condition, not dirty and not washed. We cannot accept returns for an item with any indications that it has been used.
Return shipping costs are your responsibility unless the item is damaged or defective. If you have any questions about the restocking fee as it pertains to your order please call us before we ship the product as once it leaves the warehouse we have incurred our cost.Fax Number: 1-866-323-8256
sales@bread-maker.net
http://www.bread-maker.net/contact-us.aspx
Posted on Dec 29, 2009
john224
  • 1378 Answers
SOURCE: When looking at a motor diagram, the shaft has
Exactly.
Posted on Feb 03, 2010
SOURCE: simplify the following ratios 40:50
12:38
Posted on Dec 16, 2010
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
Kawasaki zzr1100c what is the valve clearence
hi there,
this table will help you. I used to own one.. beautiful bikes easy to work on too!
Valves:
Valve clearance: Inlet 0.13 0.19 mm
Exhaust 0.18 0.24 mm
Valve head thickness: Inlet 0.5mm 0.25 mm
Exhaust 0.8mm 0.5mm
Valve stem bend 0.05 mm TIR
Valve stem diameter: Inlet 4.975 4.990 mm 4.96 mm
Exhaust 4.955 4.970 mm 4.94 mm
Valve guide inside diameter 5.000 5.01 2 mm 5.08 mm
Valve/valve guide clearance
(wobble method): Inlet 0.02 0.07 mm 0.18 mm
Exhaust 0.06 0.11 mm 0.21 mm
Valve seating surface:
Outside diameter: Inlet 30.8 31.0 mm
Exhaust 26.3 26.5 mm
Width 0.5 1.0 mm
Valve spring free length: Inner 35.5 mm 33.6 mm
Outer 40.5 mm 38.6 mm
Valve seat cutting angle 32 degrees, 45 degrees, 60 degrees
Hope it helps.. Ken
Aug 18, 2014 | kawasaki ZZR 1100 Motorcycles
What size clutch fits a 2003 gti 1.8t?
comparebanner.jpg Duralast/Clutch Set viewdetailsshelf.gif Part Number: NU31668 Warranty: Limited Lifetime Application: With 6 speed transmission
9 1/2" disc outside diameter
Notes: Spline inside diameter 1 5/16". Spline count 23.
Add More Items to Compare Add More Items to Compare Price: $316.99
STORE PICK UP SPECIAL ORDER SHIP TO HOME AVAILABLEADD TO CART Duralast/Clutch Set viewdetailsshelf.gif Part Number: NU31620FW Warranty: Limited Lifetime Application: With 5 speed transmission
8 7/8" disc outside diameter
Notes: Flywheel Included. Spline inside diameter 7/8". Spline count 28.
May 26, 2012 | Volkswagen GTI Cars & Trucks
Can not locate drive shaft
they are called half shafts or CV axles and are between the front wheels and the engine.
Mar 03, 2011 | 2003 Kia Sorento
2003 Dodge Grand Caravan v6 3.8L is misfiring
there is a possibility that you have misseated the plugs and or not tightened them all the way down
May 09, 2010 | 2003 Dodge Grand Caravan AWD
Need belt routing diagram for 1990 dodge cummins without a/c and also belt size
Here is what you need, hope it helps
# Serpentine Belt Ribs : 8
Belt Angle : 40 Deg
Outside Circumference (in) : 64.305"
Outside Circumference (mm) : 1633 mm
Top Width (in) : 1.087"
Top Width (mm) : 28 mm
secureimgcontent.asp?sg=%7b37f4584d-540e-447a-bcf4-3a321aa90c73%7d&guid=121135
Feb 03, 2010 | 1991 Dodge Ram 350
I have a 2007 Audi A3 5 door hatchback Special but no handbook was included when I bought the car. My problem is that I do not know what the tyre pressure should be for this car and having had the car for...
Look inside the petrol cap! Otherwise:Audi A3 Recommended Tyre Pressures 1.6 96 - Onwards 28 28 32 40 1.8 96 - Onwards 28 28 32 40 1.8 SE 96 - Onwards 28 28 32 40 1.8 Sport 96 - Onwards 28 28 32 40 1.8 T Sport 96 - Onwards 28 28 32 40 1.8 T Quattro Sport 00 - Onwards 28 28 32 40 S3 99 - Onwards 30 30 36 40 1.9 TDi - 110bhp 96 - Onwards 30 30 36 40 1.9 TDi - 130bhp 01 - Onwards 28 28 32 40
Telephoned Audi Main Dealers around Manchester – Macclesfield very helpful, others either disconnected or not answering. Manual costs £21.85 (inc. VAT) + postage .... Too big to actually download and print, I suspect!
Billy Boy
Mar 22, 2009 | 2007 Audi A3
2001 Grand Caravan #4 Misfiring
if it's only one cylinder... bad spark plug wire or spark plug would be suspect.... swap the plug wires from another cyclinder... at the coil pack and plug and see if the misfire has "moved"
Robert
Jan 20, 2009 | 2001 Dodge Caravan
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
