Question about Samsung DualView TL220 Digital Camera
Power turns on, lens is out if on or off, no image on either screen, my camera is completely frozen,can someone please help?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 01, 2010
  • Michael Snabel Jul 09, 2011
    Hey, i recently dropped my samsung st500 from about 3ft, whilst trying to take a photo of myself, should have used a tripod rather than balance it on a towel rail :(, 2/3 of the rims were slightly bent and a small piece of plastic snapped from somewhere and the barrel was jammed. (stuck out), when switching the camera on, it made quite a high pitched electric motor sound for a second or 2, then made the same sound for another second or 2, then switches itself back off. I opened him up as non of the above methods worked for me. It became clear instantly that the little white cog attatched to the bar with a spring on wasn't seated against the teeth of the other cog, so a man-handled it back into place, and then spent along time trying to figure out how to put the 3 piece barrel back together the right way (as i had to take this apart too to unbend the rims so it wouldn't catch), i eventually got everything back together and hey presto! Works fine! Shame a cracked the screen when repairing it, but its ok, got a replacement screen for £20 from ebay, saved alot of money in the long run though. This job requires gentle hands, and patience, if you are failing, please enjoy a cup of tea and return to camera, you will find that whatever you're trying to do will now work. :)
Blurry images
Sounds like a lens problem. If you've ever let the camera "auto turn-off" as a power-saving measure, any button pushed will turn it back on...even if it's in a case or your pocket. This puts strain on the lens as it tries to come out...result....lens problems.
Nov 13, 2009 | Panasonic DMC-TZ4 Digital Camera
My Canon PowerShot SD1000 shoots completely black pictures. The lens is open and there is no damage to the lens or the screen. The battery is fully charged and I've even tried a different memory card. It...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 06, 2009 | Canon PowerShot SD1000 Digital Camera
Camera was dropped, now lens wont retract, no image on screen,when turned on a series of buzzes and beeps then the camera turns itsself off.
Bad news I'm afraid. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either of these conditions causes the camera to shut off to prevent further damage, and either condition will require professional repair.
Oct 19, 2009 | Olympus FE-360 Digital Camera
Lens cover opens only a **** on Sony DSC-W80
Please read carefully below procedure how to remove "Barrier Block" (what you call Lens Cover)..
Turn camera power ON so Lens will extend.
Take out battery so lens will remain extended.
First silver ring needs to be removed with help of tweezers as shown in below image..
Now you will see 2 screws at front of lens, unscrew to remove barrier block (lens cover) as shown in below image..
You need to have new barrier block with following part number..
A-1205-001-A BARRIER BLOCK ASSY
Subject part is available in Part Store
Install new barrier block as shown following image..
Insert battery and power up camera to check does barrier block works fine.
Need further info, let me know.
Good luck.
Feb 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Cannot Take Pictures Anymore...
Hey BLOBO123,
I would have the camera looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. The flap that holds the batteries in could possible be purchased from the manufacturer and is probably pretty easy to replace, but the lens is usually much harder and expensive to repair. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 30, 2007 | Canon PowerShot S2 IS Digital Camera
Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Frank!!
Oct 07, 2007 | Olympus Stylus 700 / 700 Digital Camera
Lens stuck
If the lens is not coming out, its stuck, or it wont completely open or close, that is the lens assembly, that needs to be repaired. You need to take it to somebody, that can either repair it or replace it for you. There is nothing that can be done, other than that......
Jan 24, 2007 | Sony Cyber-Shot DSC-P8 Digital Camera
Samsung DualView TL220 Digital Camera Logo
204 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
