Question about T-Mobile MDA
Booting problem??? My mda looks like it keeps on rebooting. It turns on and then within 1 minute that the os version shows up it turns back off again. And then turns back on again and off again. It's a cycle. Is there anyway that I can fix this? Thanks
  • Anonymous Apr 05, 2009
    hye i have the same problem any asisstance please
    hey i have the same problem. any assistance please
Uhm ya this is an option i have not tried it but there is a good chance it would work on the mda ... i have the tmobile wing OEM rom ... youcan put your phone in bootloader mode and load that then u will have thesame OS as the wing ... if ya want a link let me know
Posted on Jun 12, 2008
My mac adress keeps changing with every reboot
We've received a few questions about this recently because the process of changing (sometimes called spoofing) these addresses has changed slightly from version to version in Mac OS X. With that in mind, we will show you how to change a MAC address in the latest versions of OS X 10.7, 10.8 Mountain Lion, and 10.9 OS X Mavericks, and OS X 10.10 Yosemite.
Launch the Terminal found within /Applications/Utilities/ to get started.
Sep 26, 2017 | MAC Computers & Internet
How do I fix an ASUS Transformer Book TF101 that's stuck in boot?
  1. Press and hold Power and Vol- until the device reboots and small white text shows up saying press Vol+ within 5seconds for recovery. Do not press Vol+.
  2. It will then prompt you to cold-boot in to either recovery or android, follow the directions on screen to select android and start.
That seems rather annoying to have to do every time you restart the ****** thing. The permanent fix requires either root access via terminal emulator under the installed version of android, or running a remote shell on it with the Android sdk. I chose the latter.
As with all ASDK tomfoolery, start the adb server
adb start-server
Check to make sure the device shows up
adb devices
Start the required remote shell session
adb shell
Run the follow magic command to make everything happy again
echo boot ' dd of=/dev/block/mmcblk0p3 bs=1 seek=0
And then reboot the device.
May 22, 2017 | ASUS Computers & Internet
Check loader..
Check Loader comes from the BIOS. Go into your computer BIOS (tap del del del) and make sure your motherboard BIOS can see the Controller. If not, contact you Mobby manufacture for an upgraded BIOS if your motherboard if it isn't too old, and your controller isn't too ancient either. Next - some controllers and PCI add on cards require to be registered within the BIOS. If it needs to be, you need the floppy or CD from the Controller maker and install it before the Mobby BIOS can see it. Remove the controller, install the BIOS update within your OS then shut down, install the Controller, and reboot.
Or don't reboot, go into the PC BIOS and look if the controller is listed.
Many times, it won't show in the BIOS itself but there will be a Logo and Identification at boot up. So keep your eye on the screen until you pass boot into the OS.
May 10, 2014 | Wytron Technology Wytron-688 DVD...
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
My HP e9120f gave me the following error message the other day. "reboot and select proper boot device..." My first thought was my hard drive was bad. I could turn off the computer and after a...
You might have another part that has gone bad. Check the RAM and see if it gives you any problems.
There is a program call mem test that you can burn to a CD and test your memory. But if your no longer able to get to the bios:
you def had a hardware problem.
Hello. I have Dell notebook-inspiron 1525. When I started my notebook, suddenly it goes for shutdown within 2-3 minutes. After restarting, it shows message mention below.Problem signature Problem Event...
Try this one first.
Boot to F8 then select Last Known Good Configuration.
If fail boot back to F8 then Safe Mode.
In safe mode try to do system restore from the time system was working fine.
After that everything will be fine.
Mar 29, 2011 | Dell Inspiron 1525 Notebook
My system hibernated and now does not boot.
What happens when you try to boot? Are you getting BSOD (Blue Screen Of Death) or does it just reboot again? Keep tapping the F8 key which will take you to the advanced boot options. You should select Safe Mode with Networking, which should load windows with minimal drivers. Once you are in Safe Mode with Networking, you can either do a system restore to a time when your computer was working properly, or uninstall any programs, updates that you installed recently. Also try turning off Hibernation once you are in Safe Mode with Networking. If that does not work, reply back with the OS version
Mar 01, 2011 | Systemax Ascent PC Desktop
I have a laptop that i tried to format and not able to boot or install OS again. so i've removed the notebook HDD and connect to other PC via usb cable. but then i'm not able to install OS on that from...
have you tried to set the BIOS boot sequence first priority(ODD) of your laptop?
try this
1. restart the system and while screen is turning on keep on pressing F2 then look on boot then the 1st should be ODD then once you did that press F10 to save and exit then try it again by rebooting system then press F12 while screen is turning on to install OS in you laptop
Oct 06, 2010 | HTC Touch Viva Cell Phone
When I turn notebook on it only powers to the screen that says f2 for set up or f12 for boot options, occasionally I can hold the f12 key while powering up notebook, release key when it comes to that...
try to reset the bios to factory defaults to do that keep tapping the f2 key as soon a you turn on the computer until you see the bios screen then using keyboard go to a tab which says boot then press f9 key press 'y' to confirm then your computer should boot properly everytime..
take a look at this picture just to show you how that screen looks if this doesn't work try doing system do system restore try this link..see the use system restore topic
Oct 02, 2010 | Toshiba NB205-N210 Netbook
When you turn the comuter on, it just shows the
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X StartupItems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
This should help get your iMac G4 back up
and running.
Jan 30, 2010 | Apple iMac G4 Desktop
T-Mobile MDA Logo
98 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
