Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
What is the air gap b/t the flywheel & coil on [11] hp engine
  • 2,841 Answers
You can set the air gap with a business card or a feeler gauge. From .020 to .045 is correct. Just make sure you slowly turn the flywheel and it never touches the pickup after you set the gap.
Posted on Oct 01, 2010
Air gap for coil
Assume you are asking for the air gap between the flywheel and the ignition coil?
Obtaining the correct gap from the manufacturer's specifications is best because although in theory a close gap is desirable for efficiency, flywheels grow as the engine heats up and a large flywheel can grow quite a lot.
Brass feeler gauges are best for setting air gaps as they are none-magnetic. A typical air gap would be in the region of 10 to 14 thou.
Mar 16, 2016 | Garden
My 5 hp briggs stopped running. No spark. took recoil off to reveal a rotten coil with wires rotted off. cleaned off the flywheel and replaced the coil with one from Napa. The engine does not have points...
Did you set the Air Gap correctly, it should be .020 inch. If the Air Gap is correct and you cleaned the pickup magnets, you should be getting spark. I have different color coded plastic sheets of the correct thickness to set the Air Gap on different engines. You could use a use a side panel from a plastic soda bottle (Mt Dew, Pepsi, ect) Place it between the Flywheel and the Armature/Ign Coil. Allow the magnets on the Flywheel to pull the Armature/Ign Coil together and then tighten the Armature/Ign Coil bolts. Carefully turn the Engine while pulling the plastic from between the Armature/Ign Coil Pickups. The Armature/Ign Coil is now properly set.
Generall speaking for a gasoline engine to run you need 3 things. (1) Spark, (2) Gas and (3) Air.
I hope this is helpful. UAW 974
Jun 25, 2011 | Sport & Outdoor - Others
What is the magneto gap for a 6HP Briggs & Stratton 12H802 series engine?
Briggs lists it as .006 - .010 on this 6 HP L-head engine. The .010 width can easily be attained by using a standard sized business card as a feeler gauge (and it doesn't stick to the magnets in the flywheel). I double up the card, loosen the coil and let the magnets in the flywheel draw the pickup legs in until they press on the card, tighten up the retaining screws (threadlocker is optional) and your air gap is set.
http://www.smallenginesuppliers.com/html/engine-specs/briggs/common_specs_single_cyl_lhead_engines.pdf
Jun 10, 2011 | Briggs & Stratton Briggs Stratton...
Air gap at the flywheel and coil on a 4 horse
Gap is .008 to .012. But use a brass feeler gauge.
Apr 22, 2010 | Craftsman 25cc Gas Line Trimmer
Flywheel/ignition coil air gap for mcculloch mac 130 chain saw
Specifications for a Mac 130 can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c1f32b7598cccadd88256c2f0019c792?OpenDocument
Ignition coil gap:
An index or business card is a good gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, tighten the coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel. HTH
Lou
Jan 07, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
No spark
You will need to remove the recoil cover, flywheel, and the cover over the points and condensor. Buy a new set of points and condensor and install them. Turn the engine over until it opens the points up and set them at .020 in. with a feeler guage. Re-assemble and make sure you tighten the flywheel tight enough or it will shear off the flywheel key. Also, before removing the flywheel check the gap between the magnet on the flywheel and the coil that the plug wire comes from. Also, make sure nothing is grounded out. (wire from points to coil).
Good luck,
Bart
Jun 11, 2009 | Air Tools & Compressors
I have a simplicity model 4211 lawn tractor with no spark.
terry, check for kill line on motor to see if grounded out,you can remove from ground clip.
also you say you checked points??????
check for flywheel to coil pickup clearance .
point type coil to flywheel the airgap should be 25- 1000ths with feeler guage. on electronic ignition coil to flywheel pickup the air gap should be set @ 10-1000ths with feeler guage. hope this solves your problem..........lemmee kno.....chris
Jun 07, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
No spark
If your engine is 11 years old it will have points @condensor under flywheel there are two wires coming from the condensor one goes to the coil and the other goes to a ground switch thats most of the time on the throotle linkage,if that wire is grounded against metal there will be not spark . the gap between coil and flywheel is 10 thousands (you can use an index card to set it .
May 16, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Chipper won't start
what engine do you have im guessing a briggs & stratton was it running previously or sitting awhile it can be a few things the flywheel key could be sheered or the points are bad or the flywheel & coil are rusted check flywheel & coil to see if rusted if so take coil off mild sand paper like 80 grit i beleave clean both to get the right gap between flywheel & coil turn the flywheel alittle bit so the magnets won't touch coil or if coil still of set flywheel to where it will touch magnets fat peice of sand paper not folded but flat sand paper about .020 gap between magnet & coil if you place sand paper against the flywheel magnet then set coil against sand paper & magnet that should give you 0.020 gap & it should start if not e-mail me i will guide you through everything to get it started
May 11, 2009 | Heavy Machinery
Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Nov 28, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
231 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
