Question about Standard Horizon CP160 GPS Receiver
CP 160 Will not pick up satellites. Have followed book and re-set unit but it still can not access satellites although every page seems to work fine
I can not put the name of the points on my gps chart 160
Posted on Sep 06, 2011
I lost my installation cd to my level one wbr-5400 wireless router. how can i install the software without it?
Sadly, CP Tech's website does not have much self-service tech support where you could download the drivers. Although, they do have email and phone number information where you can reach out and they might email you the link to the download page or email you the drivers to the router. Worst case, consider buying a router from a better known tech company that provides better tech support access online (D-Link, Netgear, or Linksys). The newer routers have plug and play features making the need for drivers unnecessary. Good luck.
Sep 13, 2012 | CP Technologies Levelone WBR5400 Wireless...
Laptop satellite 505D-S5983 numbers pad on the right of keyboard do not work, numbers at the top work just fine. I tried the num lock but still does not work. Any advice would be helpful. Thanks
Hi Guys,
I had this issue and after checking the BIOS and various other tests in safe mode, solved it by following these simple steps.
Go to "Ease of Access centre"
Choose "Make the mouse easier to use"
Uncheck "Turn on mouse keys"
Choose Apply and ok.
Worked for me, might work for you.
Cheers
Denv
May 09, 2010 | Toshiba Satellite Notebook l505dls5005
Standard Horizon CP-150 won't find satellites
Robert
It could be the RAM inside the plotter needs to be reset, Try the following procedure:
RAM Clear
Please note this procedure will erase any saved user points such as marks and routes and will put all of the internal settings back to factory default. In addition the unit will have to reacquire satellite signals, which may take a minute or two. If you have a large number of routes and/or marks you may wish to save them to a User C-Card prior to performing the RAM clear. The User C-Card is a blank memory card that is available through your local dealer or can be purchased from C-Map directly by contacting them at (800) 424-2627.
1) With power to the GPS turned off press and
hold the ENTER key.
2) Now press and hold the PWR key.
3) Keep both keys pressed until the GPS screen lights up and you see the SYSTEM TEST page displayed, then you can release both keys.
Note: If the GPS is not able to be turned off using the PWR key you can turn power off at the breaker or disconnect the power cable, press and hold the ENTER key then turn the breaker on or plug the power cable back in.
4) Make sure that the RAM menu function is selected, then press the ENTER key.
5) A sub-menu will appear that has two selections; RAM test and RAM clear, move the shuttle point knob down to select RAM clear.
6) Press the ENTER key, a prompt will appear asking if you are sure that you want to clear the RAM. Press the ENTER key to confirm and a prompt will now appear that informs you that the RAM has been cleared.
7) Press the CLEAR key and you will be back on
the SYSTEM TEST page.
8) Press and hold the PWR key until the unit turns off, then press and hold the PWR key until the unit turns back on again.
Sep 06, 2009 | Standard Horizon GPS
Setting a secuirty access password on Compaq IPAQ router CP-2W
You want to setup WPA, assuming the access point is new enough.
WPA with a Pre Shared Key (aka PSK) is what you want. This is often called WPA Home or WPA Lite or something similar. All a PSK is really is a password.
Look for this on your wireless setup menu. You should be able to set it there. There's a small chance this is on the advanced screen, although most have it on the normal screen. If you have a really old access point, you're likely going to only be given WEP options. If so, spend the $50 for a new one. You'll be money ahead in the long run... Since this is an 802.11b access point, that's almost certainly the case...
Mar 31, 2009 | Compaq iPAQ Connection Point CP-2W...
Cannot get satelite signal for magellan triton 1500.
Options:
1) Walk outside and give the unit 3 - 5 minutes to acquire satellites.
2) Push the PAGE/GOTO button on the left side of the unit until you see the satellite page and see if you are picking up satellite.
3) If 2 and 3 do not work .. then reload the firmware again.
JG
Aug 22, 2008 | GPS
Garmin 60CSx - Cant find satellites
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
Dec 29, 2007 | Garmin GPSMAP 60CSx
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Hitachi CP-X270
FN is function. Try another configuration.
May 29, 2017 | Hitachi CP-X270 Multimedia Projector
No Signal
hey i hope this issue has been resolved by now... ami i right .. if its not then jus lemme know n i l post ya the exact solution for this one ,,, i think its a very minor issue,,, plz respond
Aug 18, 2006 | Compaq iPAQ Connection Point CP-2W...
Standard Horizon CP160 GPS Receiver Logo
218 people viewed this question
Top Standard Horizon GPS Experts
Steve
Steve
Mister Danger
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
