I HAVE A PHONIC POWERPOD 740 PLUS FROM THE INPUT
I HAVE A PHONIC POWERPOD 740 PLUS FROM THE INPUT VOLTAGE SWITCH 120/240 SELECTOR THERE IS A SMALL 35X30X30MM TRANSFORMER LOOKING AT THE SCHEMATIC DIAGRAME IT SAYS T940 120/24V BUT THERE ARE 3 PINS ON PRIMARY 240/120V I PRESUME ITS 24 VOLTS OUT IF USEING 240 OR 120...BUT THE RATING I'M NOT SURE. IT FEEDS 2 X DIODES 1N004 FROM EACH PIN THEN FROM THE ONE DIODE IT GO'S TO A 7815 REG 15V INPUT. CANT WORK OUT HOW MUCH CURRANT THIS WOULD DRAW? THINK BECAUSE OF ITS SIZE IT MAYBE 6VA BUT I DONT WANT TO PUT A LOWER RATED TRANNY THAN IT NEEDS OR WILL HAVE A OVERHEATING PROBLEM. I DO HAVE THE SCHEMATICS FOR THIS MODEL BUT NOT SURE HOW TO UPLOAD THEM ANY HELP WOULD BE GREAT
  • 3 Answers
SOURCE: Bose Sounddock Power connection Schematic
http://www.redflagdeals.com/forums/showthread.php?p=7639870#post7639870
Posted on Nov 09, 2008
  • 4234 Answers
SOURCE: volt value of the zener diode no-UZL-30L
That part can be purcahsed from tritronincsinc.com for $1.07 using part number 8-719-934-21.
Or the substitute can be ordered from BDENT.COM using part number HZS30L for .33 each.
Dan
Posted on Mar 27, 2009
  • 230 Answers
SOURCE: Burnt Zener diode... Voltage spec??
On the cathode of the zener diode look for a filter cap and check its value the voltage of the zener should be less than the working voltage of the zener. Basicly its likely being used as a shunt regulator as protection and regulation of the voltage. When the zener hits a certain threshold it will breakdown and start conducting to ground until the supply regulates and then it will recover. If the filter cap for that voltage rail was 25V I would guess that the zener would probably be regulating between 12 and 20 volts. I'd pick a 15V Zener its probably +- %10 on the original and any system should be able to take a %10 tolerance as a general design rule.
Posted on May 07, 2009
  • 75 Answers
SOURCE: Car Battery Charger - Repair
thats what i did on mine they blew when i hooked the cables up backwards (gotta watch that)
but i used 130 amp alt diodes from an old tractor alt i had
Posted on Jul 03, 2009
  • 3197 Answers
SOURCE: i have an old powerlift opener. had been working
It sounds like your logic board has bit the dust. Due to the age of that opener I would suggest a new up to date model.
Posted on Sep 28, 2009
When I try and turn on my phonic 740 plus 2x220w powered mixer there is no lights that go on, it seems like it isn't getting any power?
The most likely cause is a blown fuse and fuses are cheap. I would replace the fuse and try it again. The fuse may be hard to find so I would take the fuse and try Radio Shack Fry's or any where known for electronics. If it's not the fuse it could be the power cord you could try any computer power cord to check that. If it's not any of that you could take it apart and look for the problem. I can walk you through the basics if you want.
Jun 21, 2014 | Phonic Powerpod 740 Plus 2X220W 7-Channel...
I am needing to replace my piezo drivers for the S715 cabinets and they are 8 ohm 15 watt drivers. Will these cabinets only safely handle 15 watts, or can I replace them with higher wattage drivers? I am...
No worries here, in fact you can attach a non-piezo hf driver, coupled with a 2.2uf/3.3uf MKT filter and that should do the job with ease, even better than with piezoelectric devices, hope this helps...
Sep 14, 2013 | Phonic Powerpod 740 Plus S715 PA System
Phonic Powerpod 1860 - One channel xlr input stopped working. What could cause that?
Several things could cause this... connecting it to a piecee of equipment powered from a different wall receptacle cound result in ground bounce on the building power that could destroy the input circuits. Another thing is if a static discharge hit it... There are bypass capcitors at the inout that could have shorted. Of course the fader could have failed...
Aug 12, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
Why do i have echo when i play music on my phonic powerpod 820 mixer
Visit this link to download the manual if you don't have it already. https://phonic.box.net/shared/crqxhlhmmz
This mixer has a multi-effects processor onboard, but the key is understanding the audio signal chain. There is a chance that you have your input audio going through an undesired effect, but without knowing your setup (input source, connections, mixer settings), it would be difficult to pinpoint the problem.
Apr 04, 2011 | Phonic Powerpod 820 Mixer
145 people viewed this question
 Grubhead
Grubhead
