I have a 3 yar old laptop that runs loud......i have sprayed compressed air in it, and still noise. it shuts down at times. i won't try to remove the fan. i have a heat cloth under it, but its still loud. suggestions? and what would a new fan cost to buy and have installed?
  • Computers & ... Master
  • 5,660 Answers
Perhaps you should reconsider removing the fan. You may find your particular Model/Brand of laptop's fan, not that hard to access.
The pathway that leads air to the Cooling Fan, may be of a design where it has a filter. A piece of foam-like material, essentially. The pathway I'm describing is the Cooling Duct.
Using a can of compressed air for computers was/is an excellent idea.
However if I may,
1) It needs to be sprayed only in the Intake Cooling Duct, not the Exhaust Duct.
Where air is drawn in is the Intake Cooling Duct.
2) The filter I lightly described is at the end of the Intake Cooling Duct.
Dust, dirt, hair, (Animal and people), carpet deodorizer, you name it, can build up over time, and compressed air alone cannot remove it.
The area needs to be accessed, and the foreign debris physically removed.
Q-tips, a small brush, and compressed air are used.
To show some examples:
1) Moderately easy:
http://www.irisvista.com/tech/laptops/Toshiba1805/sat1805_CPU.htm
(You can click on the photos to enlarge)
The Cooling Fan assembly is near the top.
Moderately difficult:
2) http://www.insidemylaptop.com/take-apart-asus-eee-pc-1201n-netbook/
The laptop is disassembled down to the middle section, to access the Cooling Fan.
More difficult:
3) http://www.insidemylaptop.com/take-apart-hp-pavilion-dv5-laptop/
The laptop has to be completely disassembled, (Motherboard removed), in order to access the fan.
If you wish I could do my level best to guide you step by step, and if available be able to post diagrams, photos, and a Service Manual.
(Free)
Just post in a Comment.
(Want to know more about my expertise? Left-click on my avatar)
Posted on Oct 01, 2010
Random shut down
The three most likely causes are:
1. Overheating caused by dust buildup inside the laptop. Get a can of compressed air at a computer store or office supply store. Do NOT shake the can. Turn off the laptop power. look at the rear of the laptop and the bottom panel and locate the air vents or grille. Attach the little skinny plastic straw to the button on top of the compressed air can. Point the straw right at the air intake grilles(s) and spray a 2 or 3 second burst of air. Move the straw further along the grille and spray again. There's usually an air exhaust vent on one side of the laptop and, hopefully, a bunch of dust will come flying out of that exhaust grille.
2. One or both of your RAM memory sticks is faulty. Check the laptop user guide or maintenance guide and read how to access those memory modules. Basically, you remove some cover screws on the bottom panel of the laptop (after removing the battery and power cord!) remove one stick of RAM. Replace the cover and run the laptop a while to test that module. If it works OK, shut down, remove cover and move that module to the empty slot beside it. Test again. If OK, repeat the test but this time use the other RAM module. This procedure will isolate which, if any, RAM module is faulty .... or which memory slot in the laptop is faulty.
3. Either your power cord/charger unit is faulty or the power input jack on the laptop is damaged and making a poor connection. Wiggle the cord a little when the laptop is running to see if that causes the laptop to shut down.
Other possibilities include a bd or failing hard drive or malware/virus infection. Take it to a computer repair place.
Aug 27, 2013 | Asus Systems Asus K55A Core i5...
Vacuum not picking up
Try plugging the hose that goes to brake booster and see if the noise stops couse it seems to me it has a leak..if not spray carb cleaner around the vacume hoses while it is running and where the leak is will couse the idle to go down..
May 10, 2013 | Vacuums
Laptop making loud fan noise like its overheating,
Go buy a can of compressed air and blow out the fans and vents. That should get it running quiet again.
Jun 08, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
How do I clean the fan? It's making a loud noise.
Hmm if u can open up ur computer then u can clean the fan ur self.Else if u have a Compressed Air Can,u can try spraying Compressed air to ur Fan.However even if u do so,the dust will be inside the laptop.So best is to take the Laptop to a service Center if u r not an expert in removing the back of the laptop
Dec 07, 2011 | Televison & Video
Laptop keeps shutting off,fan is very loud my dvd drive is not reading disc
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Sep 05, 2011 | HP Pavilion Dv6910us Notebook
My x205-s9349 toshiba laptop is getting hot in the area of #1 hard drive and shuts down. I have vacuumed the case out and still does the same thing. this laptop has run hot ever since it was new.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this. Use a fan assisted laptop cooling pad for addition cooling.
May 29, 2011 | Toshiba Satellite X205-S9349 Notebook
Loud fan belt type noise from laptop
There are no belts in a computer, sounds like something is rubbing in your computer cooling fan blades, get a can of Duster ( to clean dust from things) and spray the compressed air into all the vent holes to clean out any dust and debris.
May 23, 2010 | Sony VAIO PCG-K35 Notebook
Laptop just randomly shuts off
Probably overheating. Are you playing games when it shuts off?
Turn the laptop off, remove the bottom cover, blow compressed air from a compressed air can to remove dust and lint. Check that the fan can move easily. Replace the cover. Restart the laptop. Download Hardware Monitor from http://www.cpuid.com/hwmonitor.php and install. Run the program and check for CPU temp. It should never be higher than 85 C when heavy gaming or calculations are running. If temp gets to 95-100 C, Windows and or the CPU will shut down automatically to protect the CPU and laptop from any damage. As far as I know, there is no way to disable this feature.
Apr 01, 2010 | Toshiba Satellite Pro L300 Notebook
Tring to run restore disk but laptop kepts shut down
Maybe it's shutting down because it overheating. Check all your air vents for dust buildup. Use an old toothbrush to brush the dust away from the vent holes and blow air through the vents using one of those compressed air cans made for cleaning keyboards. One time I worked on a Sony laptop that I had to take apart to get all the dust cleaned out of the air vent. You can also try running your restore disk with the laptop sitting right next to a window A/C unit. Try to position the laptop so it gets maximum exposure to the cold air of the A/C unit.
If you get the laptop working again and you think overheating is a problem I recommend downloading a free piece of software named FanSpeed. Here's a link.
http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml I'll let you read the description for yourself, but in short it allows you to monitor the temperature inside your computer and to adjust how the fans react to this temperature.
Jun 02, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
275 people viewed this question
David Payne
David Payne
