Question about Remington HC-600 Hair Trimmer
Where can i get replacement blades for hair grooming
  • Remington Master
  • 1,624 Answers
You will find replacement blades for model HC-600 at shaveroutlet.com. See link below
http://shaveroutlet.com/grooming/remington-hc600-hair-clipper-replacement-blade-set-p-847.html
Posted on Oct 01, 2010
Blade won't snap back on
make sure the clipper is running when you try to snap the blade on.
Dec 08, 2015 | Wahl 8786451A Arco SE Pet Clipper
How do you adjust the head to cut various thickness of your dogs hair?
RTM. Read the manual. You're probably not using the correct blade and size.
Aug 06, 2014 | Wahl Animal Clipper Pcmc-2 Dog Cat Horse...
Blade not staying on tight
If you can pull the blade away from the clipper without pressing the blade release button then either the hook on the Latch is broken (which will mean all blades have the same problem) or the blade socket on the blade may need adjustment or replacement. Please view the part in question Latch
Mar 12, 2014 | Andis Agc Super 2-speed Clipper...
Wahl clippers
Check to see if the blade is moving when turned on. If the blade isn't moving the clipper blade may need to be thoroughly cleaned. If the blade is clean and well lubricated but still not moving you may have blown the motor.
However, if the blade is moving freely when turned on, and the hair/fur is just not being cut (or is cutting raggedly or pulling at the hair/fur) you will need to get the blade sharpened.
May 02, 2013 | Wahl U-Clip Deluxe Home Grooming Pet...
My clippers are pulling the dog hair instead of cutting, why?
Most common cause will be the blades have gone dull and should be sharpened or replaced. Check that the 2 screws on the blade latch assy are tight where it screws onto the front housing, blade off to check them. 3rd thing to check is for excessive wear in the lever that drives the blades, if it is worn replace it.
Nov 24, 2012 | Wahl KM2 Speed Electric Clipper: Two Speed...
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
Andis Super 2 Speed AGC Clippers - The blades get very hot !
Buy some Kool Lube (Oster) or Andis Blade Coolant. Both are aerosols. Your 2-speed runs faster, so your blades heat up quicker. Check them often by touching them to your inner wrist, and spray them when they are hot. A bonus is that the sprays also disinfect! (FYI a hot blade can badly burn a pet, so make sure you keep them cool)
Apr 09, 2009 | Andis 29745 Clipper Headliner Hair Trimmer
Remington HC-600 Hair Trimmer Logo
290 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
