CALL FOR MAINTENANCE ERROR C0F32 ON A MINOLTA Di1611 PHOTOCOPIES.
4 Suggested Answers
xeerie
  • 347 Answers
SOURCE: I have the error C0F32 (Minolta - 210) on my
Yes, you have to replace the parts which are necessary to be replace.If you do not want to replace the parts and also want to get rid of this problem then please perform these steps.....
1-Press utility button. 2-now press these buttons quickly stop, 0, 0 , stop, 0, 1. 3-You are now in service mode.here, scroll down and select ADJUST. 4-Now select ATDC gain. 5-Now increase the value shown on the display for example if the value is 145, increase the value to 165 or 170. To increase the value, press the C button to clear and now enter the new value by pressing the numeric keys on panel. After this press yes button and then press rest button.Re start the machine and start making copies..........
Posted on May 13, 2011
  • 6 Answers
SOURCE: how to fix error c0f32
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Posted on Apr 09, 2010
Bizhubman
  • 108 Answers
Faulty TCR Sensor
• The measurement taken by the TCR sensor (TSRS) at a
time 2.0 sec. after the main motor (M1) has started turning
is less than 5% (greater than 4.63 V).
• The measurement taken by the TCR sensor (TCRS) at a
is 19% or more (1.41 V or less).
I would start with checking the TCR sensor located on the developing unit. Make sure it isn't caked up with toner. After that I would replace the developer and then the sensor. Check the developer unit for any damage to gears and seals.
Posted on May 17, 2010
How do i fix error c0f32 in konica minolta fk118?
IT' SENSOR OF TONER ERROR.TRY TO CHANGE THE DEVELOPER.
Feb 11, 2016 | Konica Minolta Office Equipment & Supplies
Konica minolta buzz 211 printer error c0f32 ?
Off-on and press the stop bottom :) its trouble reset
Aug 23, 2015 | Konica Minolta Office Equipment & Supplies
How to clear error code c0f32 problems by minolta Di152
replace the developer and drum , clear counter and run F8
Mar 24, 2015 | Konica Minolta Bizhub 180 Di 152 152f...
Minolta DI1611 M1, M2
replace the drum cartridge, also clear maintenance counters in service mode
Dec 23, 2013 | Konica Minolta Office Equipment & Supplies
Konika minolta di1611 error xodes
You must be change the developer and the opc drum and drum cleaning blade.
Jul 26, 2013 | Office Equipment & Supplies
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Minolta di20 c0f32 error?
C0F32 Faulty ATDC Sensor E1
The value of data read by E1 is faulty. [E1 reading is 7% or
less (3.92V or more) or 19% or more (1.41V or less).]
C0F32, C0F33
Are PJ40, CN50, CN17, and PWBA
PJ15A connected properly? Connect them properly.
Is the CN50 connection dirty? Clean
Is “C0F32” or “C0F33” displayed
even when an I/C with the same T/
C as that of a new one has been
installed? Change the I/C with a new one
installed and an F8 operation run?
(Be sure to record the ATDC control
voltage setting value if an F8 operation
is to be run.)
YES Change PWB-A, install the old I/C,
and return the ATDC control voltage
setting to the value recorded. If
“C0F32” or “C0F33” redisplayed,
change the I/C with a new one.
is to be run.)
NO Change the I/C with a new one.
Jan 25, 2010 | Minolta Office Equipment & Supplies
Getting error C0f32
HOLA BUENO YO TENGO 2 MAQUINA MINOLTA 2510,3010 ME GUSTARIA SABER LOS CODIGOS DE AVERIA POR FAVOR LES AGRADECERIA MUCHISIMO .
Feb 18, 2009 | Minolta DiALTA DI2510F All-In-One Laser...
425 people viewed this question
k24674
jasbo
jasbo
