Question about AOC 4 Vn 14" CRT Monitor
Window stay on and says lumines or brightness the
Window stay on and says lumines or brightness the window does not go away or can not drag it or movie it out of the way
    Master:
  • 680 Answers
Try adjusting your brightness from the controls in front of the monitor.
Terry
Posted on Jul 10, 2014
My Up arrow key are not working how can i increse the brighness
go to controle panel then select power option .the power option window will appear .below this window there is a option "screen brightness " drag the bar ,you can adjust brightness as you need.
Aug 30, 2011 | Lenovo 3000 Y410 Notebook
I have a dell crt monitor. Luminance Temperatura pop up on the screen and it go on and off. Sometimes contrast or bright appear on bottom of the luminance temperature. How do I fix?
Sep 01, 2010 | Dell E773C 17" CRT Monitor
My 50 inch plasma tv the color and brightess is gone
This means you have lost the luminance input to the chroma decoder or final video chip. A failure of the brightness limiter may result in similar symptoms.
A few common causes are:
Check the service switch (if any). Its contacts may be dirty and moving it back and forth a few times or using contact cleaner may be all that is needed.
Check for open high value resistors around the chroma decoder IC.
Check for open high value resistors in the brightness limiter circuit.
With a scope and schematic (or even just a pinout for the chip), you should be able to trace the luminance signal to see where it is getting lost.
I have had several TVs and monitors where the delay line in the luminance circuitry has failed. Usually it's made out of glass, and inherently is fragile. Sometimes whacking the monitor would make it come back, leading to the thought of connectoritis or a cold solder joint -- where in fact it was the delay line (long rectangular unit with two to four leads). Replacing the delay line was the solution, but to check it first it'd be a good idea to look for 'in' and 'out' on the line and short the pins. The picture may be shifted, colours may not line up, but it'll tell you that it's the delay line if the picture comes back at all. It's better than looking at a saturated picture with no luminance! :)
May 26, 2010 | Televison & Video
Ipod touch 1st generation display very dark
You probably reduced the brightness one time, but you just forgot about it. To make the display brighter, do this:
>on your iPod touch screen, go to Settings.
>once the Settings window is open, you'll see Brightness from the list, tap on it.
>now, you drag the button to make the display darker or brighter. drag it to the left to make it darker, to the right to make it brighter. You'll notice the display darkens / brightens simultaneously as you drag the button.
For more iPod touch / iPhone tips, click here. Feel free to comment on my tips if you have other questions.
Mar 05, 2010 | Apple iPod touch
Adjust brightness fujitsu siemens li1818 laptop
Hallo, try by pressing Fn and while is press down press also F7 key to increase the brightness or F8 to decreased.
Hope that this will solve your problem, have a nice day.
Sep 28, 2008 | Computers & Internet
Keyboard lights
well i don't have something to say
May 31, 2008 | Samsung BlackJack Smartphone
65 INCH PROJECTION SCREEN IS SUPER BRIGHT
super bright is due to failure in video section. 1 video supply might be absent. 2 g2 voltage mighi be high gue to some part defective at ground side. 3 chroma or jungle ic not getting supply or defective. 4 luminance section defective. BUT AS you are also saying that it came once after hitting on top so there is also possibility of loose contact also. good luck.
Sep 18, 2007 | Mitsubishi WS-65819 TV
AOC 4 Vn 14" CRT Monitor Logo
91 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
