Question about Toshiba (P000343690) Sound Card
Im using a toshiba satelliete A200...da sound icon shows dat it has NO AUDIO OUTPUT DEVICE INSTALLED...i have installed the realtek sound driver n yet it stays the same...when i check about it in device manager (control panel), the "sound, video and game control port" is missing.i have reformated my laptop and installed the sound driver, and still nothing happens...What should I do??
  • 10,421 Answers
Posted on Feb 25, 2011
No sound, drivers can't be found
right click on the red X icon select playback devices there will be a red x on the speakers right click configure them
hope this helps
Jun 27, 2012 | Gateway Computers & Internet
Toshiba A200 sound problem ''no audio devices installed'' error
its the driver update . revert to your last good sound then check web for download adresseing your problem sometime just some small setting changes does it any other
Jul 31, 2009 | Computers & Internet
Asus M2V Audio problem
in the bios because you set HD audio to audio it may be that you need to download the HD Audio driver from microsoft
Apr 14, 2009 | ASUS SiS Chipset TUSI-M Motherboard
Speaker showing No Audio Output device is installed
Try to uninstalled the audio driver.then restart the machine and again install the audio driver.hope this will work for you.
Thanks
Feb 28, 2009 | Toshiba Satellite U305-S2804 Laptop
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
No Sound
ATI is the graphics card developer. Your motherboard has onboard audio that appears to be Realtek. You should not have an ATI sound driver... as they don't exist.
I'm assuming you're using WinXP to make thing simple. If you're using Vista, try to do the equivalent.
Since your graphics card is capable of HDMI, the problem could be that the card expects to output audio through your graphics card rather than the sound card. Check start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings -- go to the Audio tab and make sure it says Realtek for output. If it shows more than one output device, set it to realtek. If it doesn't show realtek, follow the below instructions, and then double check at the end that the Output device is set to Realtek.
1>Please go to HP's site and download their Audio drivers.
2>Go to Device manager -> Sound, Video, and game controllers.
2.1> Does it have an entry saying "Realtek blah blah Audio" there? If not, what entries does it have for audio? Ignore Audio Codecs and Legacy Audio Drivers.
2.2>If there's nothing there, you need to install the drivers you downloaded. If there is something there, please continue to #3.
2.3>After installing the driver, restart computer.
2.4>Once computer is restarted, go start -> Control Panel -> Sounds and audio. -> Sounds and Audio Devices /or/ Adjust Speaker Settings. Hit the button labeled Advanced and adjust the speaker setup to whatever you have - surround sound, 5.1, quad, stereo, whatever.
2.5> Go to #5
3> If there is anything that says Realtek/Azalia Audi, right click it and Uninstall.
3.1> Restart computer.
4>Install audio driver you downloaded, and perform #2.4.
5>Find the driver icon (there's probably on in the task tray) or find it under start -> Control Panel -> Sounds and audio. Set your speaker settings there as well. Audio I/O should specify what ports go to what speakers What you set in windows should match the Realtek audio manager's speaker setup.
If problem persists, please report this.
Dec 14, 2008 | Computers & Internet
Toshiba Satellite Pro A200 - Vista - Sound problems
You should check if in the device manager the sound card shows up. Also, check the BIOS to see if it is not disabled.
Oct 27, 2008 | Computers & Internet
How do i install audio output device
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down. No Audio Output Device Installed
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Regarding about sound card on my laptop
Right click on may computer and go to properties.
go to hardware tab and click harware devices.
Right click on sound Driver or Multimedia Audio Device and Click update driver.
give the path to downloaded Driver if it pick up the sound will work.
If it dont that means you dont have the reletive driver.
search the new driver and install by the above process.
Jan 08, 2008 | Computers & Internet
Computers & Internet Logo
158 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
